Largest tires WITHOUT a lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacodile, Aug 11, 2019.
  1. Aug 12, 2019 at 11:31 AM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    OP, if you're willing to start cutting you don't have to lift to fit a bigger tire. Even lifting doesn't necessarily help, since that larger tire as to go somewhere as the suspension cycles. What exactly is your goal? The more narrow the tire the easier it will be to fit.
  2. Aug 12, 2019 at 3:17 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    If you just swap to t0ns you can easily run fodees and crawl mad rocks dawg. Whatever you rub on dont worry because eventually itll just fall off or grind away, and what falls off is obviously just spare parts. Send it my dude
    *obvious sarcasm
  3. Aug 12, 2019 at 4:05 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    265/70/17 or 265/75/16 are the largest tires you can fit without rubbing, lifted or not.
    :gossip: pssst, a lift doesn't change the size of the wheel well, which is the limiting factor when it comes to tire size. Sure, a 285/70/17 will fit on a lifted Tacoma but as soon as you cycle the suspension you'll realize that the lift really did nothing when it comes to fitting bigger tires.
  4. Aug 12, 2019 at 4:18 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    To answer the OP. the largest tire thats going to fit without rubbing / cutting etc is going to be a 265/75R16 (265/70R17) sized tire. Which is one notch up from your current stock sized tire. Anything bigger in diameter or wider is likely going to rub. You can GUARANTEE rubbing with a 285/75R16 / 285/70R17
