laser bore-sighters
Discussion in 'Guns & Hunting' started by tacomaman06, Sep 12, 2009.
  1. Sep 12, 2009 at 9:57 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    what laser bore-sighters does everyone like to use? i need to get one for use with my .270, but i need to use it with my .50 cal. cva wolf, and my 12 guage mossberg slug gun. i honestly dont know alot about them, but i wanna get one thats versatile, cause sometimes i'll waste rounds sighting in at the range. thanks for the feedback.
  2. Sep 13, 2009 at 2:31 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Will, I have never used them, on the CVA pull the breech plug and also the bolt on the .270. Set out something say at 40 yards, look through the barrel then through the scope. Most of the time I use my mailbox and put an orange dot sticker on it. 9 times out of 10 I am with in 2 inches when I go to fire it.
    On the shotgun with slugs, set the target at 20 to 25 yards and fire a shot, off a bench. Make your adjustments then move the target to 40 yards, fire a shot. From a good bench with the same ammo you should be close. Make adjustments and move to 50 yards, fire another shot and you should be good to go. Most cases I give it 1" high at 50 yards, just in case I need to go out a little more.
    I have done this method to Winchesters, Berettas, and Browning's with great luck.
  3. Sep 13, 2009 at 2:34 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    cant help on your topic, but how do you like the .270?
    I'm going to be getting one asap for this hunting season
  4. Sep 13, 2009 at 2:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have used the cheap ones with the caliber adapters. None are gonna put you dead on, but you will get your rounds on the paper without too much waste. Personally, Find one you feel comfortable spending the money on.
  5. Sep 13, 2009 at 4:38 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Bill.....thank you for the info. i will try this method on the cva wolf i have......and try it on the 12gauge....but on my .270......its a semi-auto......so im not sure about that.
    rab......i have a remington 7400 .270 semi-auto. i love it man. along with the .30-06.....to me,its one of the best calibers for most hunting purposes......including elk and such.
    Chris............you got a link to the type of boresighters you are talking about?
  6. Sep 13, 2009 at 4:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  7. Sep 13, 2009 at 4:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  8. Sep 13, 2009 at 4:49 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    i have a bushnell one with the adapters and works pretty well as far as i can tell. it put my 30-06 within 5-6 inches from center
  9. Sep 13, 2009 at 4:50 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
  10. Sep 13, 2009 at 7:33 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    I've got the cheap Bushnell one in the link, it gets the job done. Sighting in my .22 was a breeze with it. I had to boresight the .17HMR though, boy was that a pain in the ass...
  11. Sep 14, 2009 at 3:25 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
  12. Sep 14, 2009 at 2:56 PM
    DellGSG5
    DellGSG5 Well-Known Member
    Dell
    San Diego, California
    2009 PreRunner TRD
    Step rail, Grill guard, bug deflector,bed lights, Window Deflectors.
    I use this one
    Site-Lite SL-500 Mag Green Laser Boresighter with SRL-100 Rifle Scope Reticle Leveler
  13. Sep 22, 2009 at 12:57 PM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
