last minute tips (spindles)
Discussion in 'Suspension' started by johnw, May 28, 2010.
  1. May 28, 2010 at 1:21 PM
    johnw
    johnw [OP] Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    hey guys are there any last minute tips you can tell me to help with the spindles i got like 2 right ups but need torque specs i think
  2. May 28, 2010 at 1:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Lowe control arm bolts are 118 ft-lbs.
    Lower ball joint is 103 ft-lbs
    Upper ball joint is 81 ft-lbs
    Axel bearing assebly bolts are 59 ft-lbs.
  3. May 28, 2010 at 2:16 PM
    johnw
    john
    orlando florida
    thanks chris
  4. May 28, 2010 at 3:19 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    make sure to take plenty of pics and post em with the other spindle thread. would be awesome
  5. May 28, 2010 at 7:55 PM
    johnw
    john
    orlando florida
    HOw did you guys get the abs speed sensor in!?!?!?!?!?!?!?!?!?
  6. May 28, 2010 at 10:41 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    IN? If I remember I just pushed it in and re-did the bolt. I cant be sure though, its been a while. I do know that it took about an hour to figure out how to get them out without messing them up.
  7. May 28, 2010 at 11:03 PM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    San Jose, CA (Nor-Cal)
    2010 SSM DCLB
    Make sure you put the ABS sensor in before you connect the UCA. You need to have the spindle bent down as far as possible to tighten the bolt that connects the ABS sensor. It's a PITA to do while it's connected. Maybe find a tie rod separater. The outer tie rods were a PITA to disconnect from the old spindle and PITA to install as well. Finally the bolts that you disconnect to take the brake line off might be extremely tight so try your best not to round the nut. That's pretty much the best sort of advice I would be able to tell you. Good luck and post pics when it's done!
  8. May 28, 2010 at 11:13 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    1 - grind the weld areas so that the calipers fit flush. test fit calipers and you will see what i am talking about.
    2 - as stated, speed sensor in before anything
    3 - install ext lines AFTER you install spindle
    4 - get alignment ASAP!
    5 - have access to brake line flare tool (i needed one to fix stripped brake hard line nut) and a puller (to pop off tie rod end and upper ball joint), both can be rented free from autozone, kragen, etc. i needed both for my install!
    thats all i can think of now
  9. May 28, 2010 at 11:15 PM
    johnw
    john
    orlando florida
    already done thanks though. nice and round
  10. May 29, 2010 at 8:39 AM
    jacob_wood
    Jacob
    2010 SSM DCLB
    Hah well that's alright. What is your plan for the rear suspension?
  11. May 29, 2010 at 11:06 AM
    johnw
    john
    orlando florida
    still working on the front cant get brake lines on the front
  12. May 29, 2010 at 12:23 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    ^ whats the problem?
  13. May 29, 2010 at 9:16 PM
    johnw
    john
    orlando florida
    brake lines wont line up with calipser and after market ones so we gotta make new solid brake lines
  14. May 29, 2010 at 9:26 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    howd you get spindles with a 4x4?
  15. May 29, 2010 at 9:27 PM
    08pretaco
    az
    you can fit you just need to slowly and carefully finesse the old hard lines
  16. May 29, 2010 at 9:31 PM
    johnw
    john
    orlando florida
    they make them im pretty sure total chaos i think
  17. May 29, 2010 at 9:32 PM
    johnw
    john
    orlando florida
    wasnt working already cut lines either gunna try to bend own tomorrow or get some stainless steel braided ones make from a local place here
  18. May 29, 2010 at 9:33 PM
    08pretaco
    az
    LAST SENTENCE:
    3.5” Lift Spindles 05+ Tacoma Prerunner, 06+ FJ Cruiser 4x2, 03-09 4Runner 4x2
    Finally a race inspired bolt on lift spindle for your 2005+ Tacoma Prerunner, 06+ FJ 4x2 and 03-09 4Runner 4x2. TOTAL CHAOS spindles are designed to add an additional 3.5” of lift and can be installed with existing aftermarket mid travel upper control arm and coil over shock packages. These systems combined provide 6”+ of lift and maximum cross member ground clearance, allowing you to Install up to a 35” tire. Our tubular tower and plate design features internal gussets along with overlay plates to add strength and reinforcement to proven weak areas. The tower includes a tapered bung that offers a pocket to access the aftermarket uniball conversion nut or thefactory ball joint. The CNC machined billet hub includes a one piece bearing carrier, and caliper mounts that are integrated into the boxed main body. To maximize strength, TC’s spindle was designed to not retain the factory sway bar. With the heavier spring rates of aftermarket coil over shocks and the increased track width provided by the spindles (3/4” per side), the sway bar removal is not noticeable. Removing the sway bar also allows for maximum wheel travel and articulation which will greatly improve the vehicles off road handling and performance. TOTAL CHAOS lift spindles come powder coated black and include a pair of D.O.T. approved stainless extended brake lines. Lift spindles that are intended to be installed with TC long travel systems must be specified at time of purchase. ABS wire tabs and brake line tabs are included to aid in routing the lines away from contact areas to prevent damage to these components.
    These will fit 6-lug 2WD vehicles only!
  19. May 29, 2010 at 9:35 PM
    08pretaco
    az
    CAMBURG:
    These are Camburg Engineering’s all new 4″ lift spindles for the 2005-2009 Tacoma Prerunner, 2006-2009 FJ 4×2, and 2003-2008 4Runner 4×2. These are a great solution for larger tires and factory ride or much need clearance for larger tires with our bolt in mid travel coilover or long Travel kits.
  20. May 29, 2010 at 9:35 PM
    johnw
    john
    orlando florida
    eh sshhh... but idk maybe he helped with somebody's????? but yes gunna get custom lines if all go's not well
