last noob question for the day...probably
Discussion in '1st Gen. Tacomas (1995-2004)' started by comanche5L, Jul 16, 2010.
  1. Jul 16, 2010 at 12:06 PM
    comanche5L
    comanche5L [OP] Member
    Fall river, Nova Scotia
    Daystar 3.5"
    ok guys ive been trying to figure what the shit you guys are talking about when you are talking about backspacing. Im used to a jeep, 3.5" BS, 3.75" etc etc, now i buy a taco and you guys are talking in +/- 45 ??? totally lost, im assuming your not using the metric system but cant figure it out.
    anyone that can shed some light id be very happy.
    im trying to figure out the stock Backspacing on my stock '00 taco, and see it i need different rims to swing 32/11.5/R15's after i get my 2.5" lift installed.
    THANKS!
  2. Jul 16, 2010 at 12:11 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
  3. Jul 16, 2010 at 8:55 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Welcome to TW. BS is confusing. As Juggernaut said, sometime folks just a assume you know what they are referring to. Maybe this will help.
    Stock (factory) backspacing for 95.5 thru 04 Tacomas is +15 millimeters (stamped right on the rims) which equates to about 9/16". 2nd gen Tamomas, +2005 models, have +30 mm of BS. A common aftermarket wheel BS is 0 mm (also referred to as 4.5" of BS). This means that many times aftermarket wheels stick out about 9/16" further than stock wheels on 1st gens.
    Anyway, translated (a bit) into english, a stock wheel on a '96 thru '04 model has a little more than 5" of BS. Actually 5.09" of BS (4.5" + 15 mm) and 2nd gen stock wheel is a little more than 5.5 " of BS. Actually 5.68" of BS (4.5" +30 mm).
    Does this help?
  4. Jul 16, 2010 at 9:38 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
  5. Jul 16, 2010 at 9:42 PM
    pittim
    Pennsyltucky
    Boujee Prius
  6. Jul 16, 2010 at 10:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You always did have all the cool pics and all.
  7. Jul 16, 2010 at 10:48 PM
    pittim
    Pennsyltucky
    Boujee Prius
    i have a folder of stuff i find relating to these trucks/gen info (like that pic) that is useful ;)
  8. Jul 17, 2010 at 3:46 AM
    comanche5L
    Daystar 3.5"
    wow! you guys are an awsome help! great explanation. i think ill save that pic too hah
    so do you guys think ill rub with the 32/11.5/R15 with the stock rims?
  9. Jul 17, 2010 at 10:12 AM
    scocar
    scocar Patron of the Farts
    pit & dig, props to you.
    Awesome info and resources. These terms and specs deserve a sticky under the Wheels topic.
  10. Jul 17, 2010 at 9:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The answer to that depends on how much, if any, lift you have. I have heard others state that one can run "32s" without a lift. But I suspect there will be rubbing under thos conditions.
    Back in the day I ran 32x11.5-15s on stock rims on my '98 TRD with a 2" spacer lift with no rubbing at all. I currently run 32x10s (255x75-17s, 0 offset, 4.5" BS) on my '02 TRD with ~2.5" of lift with no rubbing whatsoever.
  11. Jul 18, 2010 at 7:04 AM
    comanche5L
    Daystar 3.5"
    ok that works. I did order the daystar 3.5" lift (2.5" spacer + 1" body lift) i figure ill throw the spacer lift in and if it looks like it could use more ill add the BL as well.
    thanks guys
