Last Weekend's 100K Service, what I found
Discussion in '2nd Gen. Tacomas (2005-2015)' started by House Doc, Jan 17, 2012.
  1. Jan 17, 2012 at 12:37 PM
    House Doc
    House Doc [OP] Active Member
    The good thing is I found nothing unexpected. 07 DC 4.0L
    I helped my son change out his plugs, serpentine belt and coolant.
    The plugs were original I think, 3 DENSO, 3 NGK. The gap on the old plugs was .065....New plugs were gaped at .040, antisieze used. We had no problem getting the old plugs out. I followed the tips posted here and all was done in about 1 1/2 hours. The belt was a bigger pain just because of the lack of room. I took the skid plate off and laid underneath while my son helped from top side. The belt looked good but we bought the truck used and for $28 I don't have to make a roadside repair:)
    We drained the coolant, flushed the radiator, then I removed a heater hose from the core entrance at the firewall and flushed the system using the water hose. Blew air through the system to get the as much of the coolant out. Filled with distilled water and ran it a bit, drained and blew it out and filled with 50/50 coolant. We worked about 3.5 hours and he learned a lot and I saved a lot of $$$. All in all a good family outing:)
  2. Jan 17, 2012 at 12:40 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    thats awesome i wish my dad would help me out when working on the truck but he's not mechanically inclined. Honestly though its great to hear about family helping out!
  3. Jan 17, 2012 at 12:41 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Good job! Did you do change the oil in the rear differential, transfer case and front differential if 4 wheel drive?
  4. Jan 18, 2012 at 6:33 AM
    House Doc
    No other fluid changes, I am thinking about the drain/refill on the AT. Never have been a fan of the tranny flush unless you do it every 30K starting when new. It is a 2WD PreRunner
