last year for a manual transmission?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by klr07, Sep 9, 2010.
  1. Apr 13, 2011 at 10:28 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes the 6 takes a bit of time to return I find it to be no issue just shift slowly as it comes down. I have not looked but it may have a dash pot that holds it open for awhile suspect it has more to do with emissions then any thing else.
  2. Apr 13, 2011 at 1:38 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    The pedal most definitely moves when the cruise control manipulates the throttle on an 06.
    Inre OP, I smell a troll, but, since you asked, you can drive a pre A-TRAC Taco just like any other old skool manual tranny.
    It herks and jerks and the low range is a real crawler.
    You can replace throwout bearings and realize the engineering failure on the 6th gear ratio, too.
    It's like having an old pickup, except the old ones had decent rear springs....didn't ride on the bumpstops.
    If you're looking for a rugged work truck, keep looking.
