Latest KD Max tune VS latest OTT tune
Discussion in 'Performance and Tuning' started by Out2gtcha, Aug 15, 2023.
  1. Aug 16, 2023 at 9:42 AM
    Tacodriver13
    Tacodriver13 Well-Known Member
    Raleigh, NC
    2022 Grey Tacoma TRD Sport
    Doing a little bit at a time.
    Switch to OTT and you will know the difference. :burnrubber:
    Cushmaat likes this.
  2. Aug 16, 2023 at 12:35 PM
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    OTT for the win here. Completely different truck.
  3. Aug 16, 2023 at 12:38 PM
    greyboxer
    greyboxer Well-Known Member
    Pittsburgh
    2022 TRD Sport Army Green, 6MT
    Had KDMax to start and it wasn’t exactly perfect for me. Loving OTT on my manual taco, but wishing I had kept oem throttle tip in. Don’t recommend medium, as it gives too many beans even with very sensitive throttle input.
  4. Aug 16, 2023 at 1:23 PM
    3GTCMLMTD
    3GTCMLMTD Well-Known Member
    2022 Limited
    I have an auto. I used to run OTT with the Spicy/Race setting. During winter, I definitely had to switch Mild/Medium. I have all three of the tunes by the different makers. Not running OTT now, but might need to put that back on the truck again and see what differences I find.
  5. Aug 16, 2023 at 2:44 PM
    Out2gtcha
    Out2gtcha [OP] Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    Thanks for all the replies folks, the info is all appreciated.
    I've got a Tune/undercoating event being held here in Omaha this weekend, and @DamesAGTacoOR from OTT will be there so will hopefully get a chance to talk about things.
    Merling likes this.
  6. Aug 16, 2023 at 3:10 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I don't have a dog in the fight (except i run kdmax 10), but there is no way kdmax is less power than stock. I've been modding cars (hobby, not professional) since 1998. I am fully aware that there are ways to trick yourself into believing you made power, but the difference is not small with that tune. Ott may be way better, but dyno sheets can be less than helpful. Just look at all the +15hp graphs you see for some of the more dubious bolt on garbage. I'm not saying there is anything shady going on, but I don't believe the stock vs kdmax comparison.
    QwickC, usmc2msu, khine13 and 7 others like this.
  7. Aug 17, 2023 at 2:32 AM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    I would go with the OTT then. I had an older version of the kdmax not the latest 10.0 version so I cant make a fair comparision between the two. But i can say Im happy with the current OTT i got a few days ago
  8. Aug 17, 2023 at 3:12 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Every vehicle is different but I can't believe this stock vs KDMAX tune someone felt no difference just not buying it. I have been on every KDMAX tune and all were improvements over the stock tune as I could always tell a difference and every updated tune just got better. I have had several muscle cars over the years with custom dyno tunes and can say a tuner can manipulate a dyno to read different numbers. Some dynos read lower. Keep in mind these numbers can be affected by heat, humidity how many pulls to get a great baseline and as much as tire tread. My drag slicks always showed a lower number so comparing between two tunes with little differences can be difficult. I have never been on a OTT tune but do hear good thing and if your into tuning cars and have a knowledgeable understanding of the parameters then I would like to think they may be close. I have been very happy with the KDMAX tunes and can only speak of their tunes. I think it boils down to competition as who wants to be the best and the way they market their tune.
    QwickC, usmc2msu, drizzoh and 6 others like this.
  9. Aug 17, 2023 at 5:16 AM
    98tacojunky
    98tacojunky Well-Known Member
    Upstate NY
    2019 TRDOR double cab
    I personally moved from stock to kdmax 9. The only difference I felt was the throttle sensitivity. But that is simply what the program in (light, medium, sport) and would essentially be no different than a pedal commander. My truck still wouldn’t hold 6th going down the flat highway. Still gear hunted in the slightest of inclines at speed. There was no difference for me outside of the sensitivity. I was shocked as were the guys at KDmax.
  10. Aug 17, 2023 at 6:50 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Just to be clear, downshifting on an incline is not the same as gear hunting.
    usmc2msu, bulalo and Chew like this.
  11. Aug 17, 2023 at 7:00 AM
    98tacojunky
    Upstate NY
    I’m aware. The vehicle will upshift and downshift constantly on slight inclines and even flat highway depending on the conditions. It’s highly annoying. Was 10x worse when I was running an aftermarket exhaust too.
    ktbell444[QUOTED] likes this.
  12. Aug 17, 2023 at 8:21 AM
    Tacodriver13
    Raleigh, NC
    Drive a Taco that has an OTT and you will know the difference.
    33yrsoftoys likes this.
  13. Aug 17, 2023 at 8:24 AM
    VaToy
    Parts Unknown
    Why, I already have a tune from kdmax that I'm perfectly happy with and don't really care to change that.
    TacoManOne likes this.
  14. Aug 17, 2023 at 8:31 AM
    Tacodriver13
    Raleigh, NC
    I was just suggesting that for folks that want to know the difference between the two to drive a truck with each tune on it. I am sure each one has there pluses and minuses. :cheers:
  15. Aug 17, 2023 at 8:41 AM
    #35
    czukie
    czukie Well-Known Member
    Colorado
    ‘23 Tacoma Access Cab
    Bummer to hear about the latest KDMaxx. I had an older KDMAxx (whatever was around in like 2019 I wanna say) and then got a new truck with OTT in 2022. Kinda preferred KDMaxx as the OTT felt a little too “lurchy” in slower moving traffic/lower speeds.
  16. Aug 17, 2023 at 8:50 AM
    #36
    Tacodriver13
    Raleigh, NC
    No matter what tune you have the turner can usually get the lower speeds to your liking. Take it back to the tuner to have them reprogram it.
    joba27n, czukie and unclewede like this.
  17. Aug 17, 2023 at 10:08 AM
    #37
    shiz-nick
    shiz-nick Jack of All, Don't Know Jack
    SoCal
    '22 DCSB OR, OTT, 5.29, on 33s
    As someone who has ran the latest of both KDMax and OTT, I can weigh in here.
    I had been running KDMax for a while, but I was swayed by the OTT Truth Be Told page on their website to give it a shot.
    Those dyno runs are no joke. The power difference down low is immediately obvious.
    KDMax felt like it just adjusted the throttle, and tackled the gear hunting issue by having the transmission hold gears longer before downshifting.
    OTT not only increased power (sub 3000 RPM is great now), but the transmission tuning is a lot better at keeping you in the power band, and the shifts are undeniably smoother. Also, I’ve noticed the torque converter unlocks/locks in a more sophisticated way on OTT.
    I’ve found OTT’s throttle sensitivity to be better - I used the lightest option on both.
    It all adds up to a significant difference, and at this time, OTT is objectively the better tune.
  18. Aug 17, 2023 at 10:18 AM
    #38
    Out2gtcha
    Brian
    Omaha, NE
    Thank you!
    Just what I was after, someone who has had both of those tunes latest versions.
  19. Aug 17, 2023 at 10:23 AM
    #39
    Tacodriver13
    Raleigh, NC
    I could not have said it better myself. Great Job! :burnrubber::cheers:
    PNW15 and Out2gtcha[OP] like this.
  20. Aug 17, 2023 at 12:42 PM
    #40
    Hossleryota
    Hossleryota Well-Known Member
    So out of the 1,000+ kdmax customer. No one(outside of kdmax or ott) actually dynoed their own tacoma(before and after)?
    Thats funny.
    K9chita likes this.
