Latest KD Max tune VS latest OTT tune
Discussion in 'Performance and Tuning' started by Out2gtcha, Aug 15, 2023.
  1. Aug 17, 2023 at 2:00 PM
    #41
    North7
    North7 Well-Known Member
    2022 trdor
    Not for measly performance increases. Fixing the shifting is the key but only if cruise isn't on.
  2. Aug 17, 2023 at 5:01 PM
    #42
    spicy_fish_taco
    spicy_fish_taco Well-Known Member
    '18 2.7L Taco 4x4 Access Cab
    most people get tunes on their tacos for gear hunting problem. its more about how the transmission shifts to get rid of gear hunt then seeing how much power a tune makes.:thumbsup:
    usmc2msu likes this.
  3. Aug 17, 2023 at 5:13 PM
    #43
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    KDMAX did feel very very underpowered when I tried it briefly. Couldn’t handle that. I’ve tried Blackhawk, Valley Tuning, and CVC before that. Now I’m on OTT. It feels like the most refined balance of power with smooth shifting of all the tunes mentioned.
    Tacodriver13 and 98tacojunky like this.
  4. Aug 17, 2023 at 9:12 PM
    #44
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Dyno runs and results can be skewed very easily. unless this was the exact same dyno, the exact same day, with the exact same operator, using the same truck, same parameters, and same correction... I dont believe that posted comparison at all. you can make the dyno read almost any number you want. take these reports with a grain of salt. Ski
    QwickC, Chew, VaToy and 1 other person like this.
  5. Aug 17, 2023 at 9:31 PM
    #45
    shiz-nick
    shiz-nick Jack of All, Don't Know Jack
    SoCal
    '22 DCSB OR, OTT, 5.29, on 33s
    From the Truth Be Told page on the OTT website:
    The Test: Test 8 different calibrations on the same truck, same dyno, same fuel, same day, etc... Eliminate all variables where possible and establish that the runs presented are repeatable and representative of the mapping of that calibration.”
    Yes, take with a grain or a whole block of salt, but they’re at least testing on the dyno appropriately.
    I mean, you’ve got to be suspicious of the KDMax claims too then, right? Especially when they had the “operator’s explanation” to justify why they did their dyno run in 4th gear:
    The 3rd gear vs 4th can skew results. The real reason why most people use 3rd in these trucks is because of wheel speed. In 4th we ran this truck to 140mph, clinching ourbuttcheeks the whole time. At these speeds, driveshaft failure can occur from critical speed failure. Fortunately, we didn't have that problem, we just sent it for the science.”
    “That’s just like your opinion man.”
    Gmak621 likes this.
  6. Aug 17, 2023 at 10:10 PM
    #46
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    4th gear is about 1:1 gear ratio. 3rd is higher 5th is lower. So dyno in 3rd will run more hp and in 5th less hp.
    QwickC likes this.
  7. Aug 17, 2023 at 10:37 PM
    #47
    shiz-nick
    SoCal
    True, but the point of these dyno runs is to compare results of a tune versus stock. With all else being equal, you just need to do all runs, both tuned and stock, in the same gear to see the difference between the two.
    I'm suspicious of anyone who would agree to running a Tacoma to 140mph because it more accurately measures the trucks power in a 1:1 gear ratio.
    TacoManOne[QUOTED] likes this.
  8. Aug 18, 2023 at 12:34 AM
    #48
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Look, you need to look at tunes from a different angle. We don't care about dyno results. What we care is (at owner):
    -no dead pedal in top gears, especially forcing a downshift.
    -proper upshift/downshift points
    -Auto tranny temps within normal and we don't cook TC in slow traffic driving
    -no or minimal misfires.
    -tune can handle 87 octane(knock and knock correction in the hot weather)
    -decent mpgs
    - both injection modes are working correctly.
    All this information is not advertised and I'm not going to pay $$ to find out.
    AODRN, Chew, bulalo and 2 others like this.
  9. Aug 18, 2023 at 1:04 AM
    #49
    3GTCMLMTD
    3GTCMLMTD Well-Known Member
    2022 Limited
    So, what are you running on your truck? Which tune, or no tune? Curious.
  10. Aug 18, 2023 at 1:08 AM
    #50
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I'm sure both companies have very knowledgeable tuners and can only assume that the tunes would be very close as customers of both tunes are overall happy. Its hard to compare these tunes back to back on the same truck given a few hundred miles should be logged on that tune to see the real results. I'm sure both companies tune within limits of the tune being safe and I don't think we have seen any catastrophic issues being related to tunes so they are doing something right. Woohobbie has tuned my truck since KDMAX has been in the business and I can say I have been happy with every tune as each update gets a little better and more refined. Each tune is going to be effected in some way because of weather, weight of the vehicle, tire size, and the driver. If OTT is so much better I challenge any OTT tuner to tune my truck and let me give it a try and I will gladly post on here. KDMAX tunes have served me well my Tacoma and 4Runner, my families Tacomas and lots of friends I send their way. I have nothing bad to say whatsoever about OTT tunes as their is enough vehicles out there to tune for everyone. I'm a big supporter of KDMAX long before OTT came along and I have been very satisfied. Only way I think to nail the perfect tune is a true dyno tune, keep in mind we're all running a can tune of some sort. We would still be up shits creek hunting for gear if it wasn't for these guys.
    K9chita, usmc2msu, bulalo and 3 others like this.
  11. Aug 18, 2023 at 1:15 AM
    #51
    Tacodriver13
    Tacodriver13 Well-Known Member
    Raleigh, NC
    2022 Grey Tacoma TRD Sport
    Doing a little bit at a time.
    I think this will be one of those discussions that go on to the end of time.....Just like the ford and chevy people. What part of VA do you live in?
  12. Aug 18, 2023 at 1:16 AM
    #52
    VaToy
    Parts Unknown
    Suffolk area, 2.5 hours from Raleigh.
  13. Aug 18, 2023 at 1:21 AM
    #53
    Tacodriver13
    Raleigh, NC
    I will be in Suffolk area with in the next few weeks to visit a friend. Maybe I will let you drive my Taco. and we can see if there is any difference. I bet they are somewhat similar. :cheers:
  14. Aug 18, 2023 at 1:23 AM
    #54
    VaToy
    Parts Unknown
    Sounds great just hit me up. I may be at the beach house in OBX till next month, might leave in a week.
  15. Aug 18, 2023 at 1:26 AM
    #55
    Tacodriver13
    Raleigh, NC
    Will do!...I come back to VA often. I use to live in the Richmond area and have friends in the Tidewater area. Enjoy your time in the OBX.
  16. Aug 18, 2023 at 1:33 AM
    #56
    VaToy
    Parts Unknown
    Thank you. LOL, I was just your way about 3 weeks ago.
  17. Aug 18, 2023 at 9:24 AM
    #57
    Vlady
    Issy, WA
    Currently latest KDMAX, but I have Nexus variants presented in the comparison.
    And this is where I can draw a comparison between 2 tunes in those posted dyno results vs day to day driving. One with more power in the dyno was tapping out on the same hill and dropping gears down to 3rd doing below 2500 rpms, other eats the hill in 5th at same rpms (87 octane).
  18. Aug 18, 2023 at 10:12 AM
    #58
    3GTCMLMTD
    2022 Limited
    Thanks for the reply. I am also running KDMax now. I have purchased tunes from the three makers to compare them and see which I like best. The comment on daily driving vs. dyno results I agree with. You can immediately feel the difference between a stock truck and one running KDMax. My truck acted the exact same way using a different tune on many hills around here that I drive daily, so I can see that difference comparing them on the exact same route.
    TacoManOne likes this.
  19. Aug 18, 2023 at 10:31 AM
    #59
    Vlady
    Issy, WA
    Yeah, when you go from stock to any tunes, your cheeks are flushing with excitement.
    Folks who were tune hopping for past 5 or so years, not so much.
    3GTCMLMTD[QUOTED] likes this.
  20. Aug 18, 2023 at 12:23 PM
    #60
    3GTCMLMTD
    2022 Limited
    Definitely. It is nice to get newer versions, though. Almost makes you feel like you got a new truck again with the updates they do.
