Lawn Irrigation: Zones running 2x in a row
Discussion in 'Garage / Workshop' started by Zac808, Apr 7, 2013.
  1. Apr 7, 2013 at 12:18 AM
    Zac808
    Zac808 [OP] Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    My automatic sprinkler system runs two times in a row. I only have two zones. The system will come on as normal to run zone 1 then 2, and then does it all over again. I completely reset the control and still no-go. The controller is a Rainbird E6-C. I googled w/ no luck.
  2. Apr 7, 2013 at 10:31 PM
    acdronin
    acdronin Well-Known Member
    Does your controller have more than one program? You either could have multiple start times on one program or you may have start times on two different programs.
  3. Apr 7, 2013 at 11:02 PM
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    Probably more likely than a concentration of tachyon particles in the controller.
  4. Apr 8, 2013 at 12:15 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Nope. No start time for other programs. Also, no run time for other programs.
  5. Apr 12, 2013 at 4:59 PM
    fishbomb
    fishbomb Well-Known Member
    nh
    sr5
    bilstien coil overs add aleafs With bolstiens in rear, mickey thompson mtz tires 285/75r16 on 16x8 dick cepek dc2 wheels. Hella black magic 500 lights up front.
    We used to hide a blow out program in the clock memory. What type of timer?
  6. Apr 12, 2013 at 5:08 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Rainbird e6-c.
  7. Apr 12, 2013 at 5:27 PM
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    05 double cab SR5 4x4
    TRD air filter, exhaust tip, tinted windows, upgraded grill, OEM LED tail lights, LED DTRL'S, Matts 123 skid plate, 4Runner Mirrors, 17 inch OEM 4runner wheels
    Does the controller have custom setting mode, mine has like A,B,C for custom mode, you could try that mode and see if it does the same way, also check all wire connections at the valves.
  8. May 24, 2013 at 4:30 PM
    podo74
    podo74 Member
    Mark
    Kona
    '05 DCAB
    got a soak time option that might be activated?
  9. May 24, 2013 at 4:32 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    Probably not the case but on mine if it is set for say 150% of normal it will run though normally and then a second time as well. :notsure:
    do you have the manual for it?
  10. May 25, 2013 at 4:30 AM
    fishbomb
    nh
    sr5
    Just go get a hunter pro c clock and toss that rain bird controller in the trash
  11. May 25, 2013 at 7:04 AM
    acdronin
    X2
  12. May 25, 2013 at 7:12 AM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road Vendor
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    My landscapers keep mine set similar, t runs all the lawn zones for just a few minutes, then does drips, shrubs etc. then back to the lawn for a longer time. They say its better to get it wet for a set, let it soak, perk up then water it again. Makes sense to me, it's green so I don't argue.
  13. May 25, 2013 at 7:29 AM
    acdronin
    Basic rules of thumb for controller programming:
    Clay soil: Longer run times, less frequency (days per week). Sandy soil: Shorter runs times, more frequent. Water slows down in clay and you need to give the water time to move down the water column and get the roots to follow it. If you only keep the top two inches wet, you won't get good root growth.
    Cycle and soaks: As soon as water begins to runoff the landscape, stop watering, if you still need to finish a run, do a second start time or cycle and soak, (if your controller has the function), the second start time is essentially the same thing.
  14. Jun 26, 2013 at 11:32 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    are those pop ups hard to replace? I have one that dribbles water
  15. Jun 26, 2013 at 10:30 PM
    acdronin
    When it's off or on?
  16. Jun 27, 2013 at 8:20 AM
    coffeesnob
    VA
    Just when it's on.
  17. Jun 27, 2013 at 8:28 AM
    acdronin
    They thread out, dig around the head a little bit and you should be able to thread it out, if you do it carefully you can avoid soil or rocks falling into the threaded pipe below, change over the nozzle from the old one to the new one, if you do get soil in the pipe, thread just the lower part of the pop up into the ground and turn on the valve briefly to flush out any dirt, thread on the top part of the pop up and aim the nozzle, done.
  18. Jul 4, 2013 at 11:26 AM
    coffeesnob
    VA
    thx
