Lazy lazy 4 cylinder
Discussion in 'Performance and Tuning' started by Meangene, Aug 4, 2012.
  1. Aug 4, 2012 at 10:06 AM
    Meangene
    Meangene [OP] Member
    Pass christian,ms
    Tacoma 4x4
    Lifted
    Hey guys I'm new here so go easy.. I have a k&n air ntake kit installed. 33 inch tires and I have to down shift going up hill on the interstate that an automatic wouldn't even down shift on. I am getting around 17 or 18 miles to the gallon. I want more power and mileage. Looking for reasonable mods to get there. It's a 2.7 liter toyota Tacoma 4x4...
  2. Aug 4, 2012 at 10:09 AM
    PreRunner03
    PreRunner03 Hail State
    03 PreRunner Double Cab TRD
    With the lift and tires, it sounds like you are getting good mileage. It is a 4-banger, not a V-8.
  3. Aug 4, 2012 at 10:11 AM
    Meangene
    Pass christian,ms
    Tacoma 4x4
    Lifted
    I have a friend getting 19 an 20 with identical truck. It just seems real lazy
  4. Aug 4, 2012 at 10:12 AM
    jandrews
    '09 FourDubDee TRD OR
    Yup.
    Yup.
    Don't we all.
    Regear, Supercharge, or take the tires back off.
  5. Aug 4, 2012 at 10:14 AM
    jandrews
    Is he also on 33 inch tires? Do you drive exactly the same roads daily? Is he gentler on the skinny pedal than you? Etc.
  6. Aug 4, 2012 at 10:17 AM
    Meangene
    Pass christian,ms
    Tacoma 4x4
    Lifted
    Supercharging a truck with 200,000 miles isn't a goit idea tho huh and probably expensive..
  7. Aug 4, 2012 at 11:16 AM
    jandrews
    Your only realistic options to improve power are forced inducation and regearing. Both are expensive. Everything else (like your K/N intake) just makes noise and does nothing for power.
    Bigger tires have the same effect as gearing your vehicle upward. Sorry, but you can't beat physics.
  8. Aug 4, 2012 at 11:24 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    regear and keep in mind its a 4cyl tacoma. it will run for a long long time if maintained and will serve you well.
  9. Aug 4, 2012 at 11:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Try adding about 5psi or so to your tires. Depending on there current pressure you might be low or not. The added tire pressure will gain you MPG. It will decrease your tires' rolling resistance.
  10. Aug 4, 2012 at 11:58 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    ^There is your power loss, also you are a 4x4, that adds more weight and geared differently. If you are really concerned about gas mileage, run stock tires. Downshifting is normal, 5th has no power for climbing.
  11. Aug 4, 2012 at 11:59 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    No way your going to get more power out of the I4 without dropping major cash.
    Just be happy with what you got or sell it and get a v6. Adding huge tires and a lift will of course effect your MPGs.
  12. Aug 5, 2012 at 12:24 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    my reg cab wasnt a slouch with 285's... but i had a 5 speed, and it came with 4:10's.. i get better mileage with my DCSB TRD OR Auto with 285's as it is 3:73 geared and the v6 doesnt work double overtime to move the 285's..
  13. Aug 5, 2012 at 12:33 AM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    So you have a 4 cylinder with 33" tires, and you want both more mileage and more power??
  14. Aug 5, 2012 at 12:35 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    LOL wut.. sell it and buy a V6 if you want power. you cant have power and mpg.. you give one up for the other.
    I get 16-18 mpg and have plenty of power.
  15. Aug 7, 2012 at 12:58 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    My v6 is slow :eek:
