Lazy mans, Fog Light On Anytime Mod
Discussion in 'Lighting' started by armyofsquirrels, Feb 21, 2013.
  1. Feb 21, 2013 at 1:01 PM
    armyofsquirrels
    armyofsquirrels [OP] Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    Not sure if anyone else has taken this approach to the fog light mod. Basically I tied them into the parking lights. No need for drill/installing a switch or running wires through the fire wall or any of that "effort".
    I have just standard bulbs NOT HIDS. I have the 4cly SR5 and didn't have the relay/wiring pre installed like the V6 seems to.
    They stay on through all the light cycles, and turn off when you turn out your lights.
    Tapped the ground next to the battery
    I'm sure this isn't the best way but it works.
    Fogs with parking lights
    Light switch
    Showing that the Highbeams are on
    Highbeams and fogs
    Thanks leave your interesting or creative comments in the comment section beeeeelllllloooowwww. Haha
  2. Mar 18, 2013 at 6:46 PM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Looks like a good idea. I personally try to never use those crimp connectors unless its just temporary until I solder up the connection.
  3. Mar 19, 2013 at 9:13 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    x2! Your approach is all sorts of messed up. If you have existing fogs, all you had to do was tap the green wire (marker light power wire) and run that to the fog light relay (bend the tab out on the relay, connect the wire, reinstall relay and done). That way the fog light are still being powered off their own fuse, not jumping off the marker light fuse. It's your truck, but what you've done is generally bad practice.
    Also, I second not using those vampire clips. Solder and heat shrink FTW :cool:
  4. Mar 19, 2013 at 8:16 PM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    OP you're overloading the circuit to the marker lights, which is asking for trouble. You can fix this in about 5 minutes by adding in a relay as mentioned above.
  5. Mar 20, 2013 at 5:15 AM
    Pugga
    Massachusetts
    F-150 Mod
    If you have factory fogs, you don't even need to add a relay. Just run the marker light wire to the existing fog light relay.
  6. Mar 20, 2013 at 12:25 PM
    Aw9d
    Aw9d That one guy
    Az
    x3
  7. Mar 20, 2013 at 4:24 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Another vote for relay.....its just safer
  8. Mar 20, 2013 at 8:28 PM
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Nope didn't have factory fogs, so no luck with the relay. Wouldn't it just trip the fuse if something goes wrong?
  9. Mar 23, 2013 at 10:33 AM
    joes06tacoma
    Joe
    Central Coast, CA
    I'm kind of surprised you haven't blown a fuse. With the small gauge wire feeding the parking lights, that actually scares me quite a bit.
    Yes, in theory you should blow a fuse before melting any wiring, but you are WAY over the amount of power that should be drawn through the tail/parking circuit.
    Go get a relay kit from NAPA or Kragen or any decent auto parts store. It's going to come with a relay, switch, and wiring. Most are for a pair of 55W lights. You just don't use the switch. Instead, tap that wire into the parking circuit. That way you have the same function you have right now with your method AND you won't burn down your new truck.
  10. Mar 23, 2013 at 10:45 AM
    Chepo
    Chepo Tankoma!
    Mexico City
    '11 TRD Sport
    ARB front bumper, Custom Rear Bumper, Safari Snorkel, Led Lights all over, OME Lift
    As everyone has stated... The relay+fuse is the way to go! If you dont do it, with the time it will cause you a problem that will take more than 5 minutes... That circuit is overloaded!
