Lazy Seat Belt Fix ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kgw, Nov 2, 2012.
  1. Jul 10, 2018 at 1:33 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I just straight out replaced my driver's side seatbelt with a brand new one from Camelback Toyota since the webbing was all torn up. I paid $149.02 shipped from Camelback Toyota.
    Massive improvement over the old one.
    Area51Runner likes this.
  2. Jul 10, 2018 at 1:36 PM
    SierraMare
    SierraMare Well-Known Member
    Ted
    Alaska
    2001 TRD OffRoad Xtracab, stepside bed, 2.7 L, 5-speed manual
    ARE cap, BFG KO2 (LT 245/75R16), Front Bilstein 5100 with OME 2881 coils, Rear HS 3-leaf progressive AAL.
  3. Dec 3, 2018 at 9:10 AM
    Colchicine
    Colchicine Well-Known Member
    Newport News, Virginia
    | 2000 | 2.7L | 4x4 | Auto | Standard cab |
    I have two problems with my seatbelt, and they directly oppose each other.
    1) as show here, the seatbelt doesn't retract sufficiently.
    2) while wearing the seatbelt, it constantly pulls tighter and quickly becomes uncomfortable across my lower abdomen.
    I'm fairly typical, 20lbs overweight with a bit of a gut. Sitting down and having the seat belt constantly putting more pressure where my belt is requires me to manually pull out the seat belt and hold onto it, forcing me to drive with one hand.
    So I'm thinking about NOT fixing my seat belt. Is there another solution?
  4. Dec 3, 2018 at 9:37 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Have you tried cleaning it?
  5. Dec 3, 2018 at 1:03 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Mixed results here, mine wouldnt retract, messed with em, still nothing. So i bought two new ones, their still "lazy", They roll up I'd say about 90% of the time, still not acceptable to me. These are OEM also.
  6. Dec 3, 2018 at 2:15 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    My seatbelt is pretty oily/dirty so maybe I should give this a shot.
    I've also put "universal replacement" seatbelts in my Jeep and they retracted fine so that will be my next choice
  7. May 5, 2022 at 9:09 PM
    desert-rat
    desert-rat Well-Known Member
    somewhere in Utah
    2001 Tacoma Limited TRD SC DC
    I've cleaned my seat belts using a bucket of hot soapy water. I usually do them at the same time when I shampoo my carpets.
    For soap I use 1/4" cup of Oxy-Clean, mainly for getting rid of smells, I use a couple ounces of a degreaser concentrate (any will do, I use the purple colored Simple Green HD), and a few ounces of carpet cleaner concentrate (any carpet cleaner, I get my concentrate at Home Depot in a gal). Mix it up in a bucket with 2-3 gallons of hot water until the oxy clean dissolves.
    If you are super lazy, you can just do this without disconnecting the seat belt, but it's harder to do the whole seat belt that way. If you can disconnect one end it's easier. I just pull as much of the belt out as I can, and clamp it off as close to the retractor or trim as you can so it doesn't retract. Then put the loose end that you pulled out into the bucket of water right on the seat - let the degreaser soak in for a several minutes. Then pull the belt out, lay it across the seat and scrub like hell with a super stiff nylon brush. Get both sides of the belt. Put it back in the bucket again if it's really nasty, another soak... more scrubbing. Rinse it off good with some fresh water from the hose. When you're happy with how clean it is, you can just leave it pulled out until it dries. I use squeeze clamps (like for wood working) to keep my belts from retracting while I clean them / dry them.
    The belts come really clean and slide much better through the seat belt retractors after being cleaned like this.
    BTW, I use the exact same mixture right on my cloth seats and carpet to clean them. But when doing carpet, instead of a bucket, I mix it in a 1 gallon container, like a milk jug. Drill a hole in the lid and you can just shake it upside down to spread it around on your carpet or seats. Scrub with a brush like hell. Don't worry about making a puddle. Get the dirt nice a loose, adding water from a hose sprayer. Then vacuum up the mess with shop vac, and repeat until super clean and good smelling. On a warm day, everything dries in an hour. I even pull up the threshold trim at each door to vacuum under the carpet. It's super clean under there and my Taco always smells nice!
