LB Joints by Toyota, from Toyota
Discussion in '1st Gen. Tacomas (1995-2004)' started by DadFred, Feb 22, 2025.
  1. Feb 22, 2025 at 12:24 PM
    DadFred
    DadFred [OP] Member
    F
    2003 Tacoma Prerunner Ltd
    I'm reading in the forum that Lower Ball Joints are no longer available from Toyota. I'm also finding them available at Toyota of Richmond.
    Email from them...
    Hi,
    The ball joints ordered are incorrect for your VIN. The correct part number is 43330-39556 and 43340-39436. The bolts are also sold separately. The bolts are 90119-10933.
    Would you like us to correct this on your order?
    Thank you,
    Ourisman Toyota of Richmond Parts
  2. Feb 22, 2025 at 1:50 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Lower Ball Joints are most definitely still available. I don't know where you read on TW that they are not, but we should get that corrected if you found it somewhere.
    You can find all the correct part numbers for LBJs themselves (there are several that are equivalent LBJs with different part numbers) as well as bolts, and how to do the replacement here:
    Step-by-Step Replacing Lower Ball Joints (LBJ) on a 1st Gen Tacoma – AdventureTaco
    Black97v6MT and TACOTU3 like this.
  3. Feb 22, 2025 at 8:49 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    I bought oem lbj a couple months ago. They are still available. I ordered mine from roseville toyota.
    MadNachos likes this.
  4. Feb 23, 2025 at 4:26 AM
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    have these LBJs ever went on backorder like the CV boot kit did last year?
    hope you got a good dealer discount off MSRP on those from Roseville!
    the MSRP on these are very close to 200$ each now
  5. Feb 23, 2025 at 5:35 AM
    LightsOff
    LightsOff Well-Known Member
    2000 SR5, V6 4WD
    I just ordered these the other day:
    Part No.: 04005-03235
    JOINT ASSY, LWR BALL 195.03
    Part No.: 90119-10933
    BOLT, W/WASHER 21.40
  6. Feb 23, 2025 at 1:39 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    They are available and you want the bolts.
  7. Feb 23, 2025 at 2:01 PM
    slodoug
    slodoug Well-Known Member
    trying to change mine right now (5 lug 2wd) but my tie rod bolt is stuck in. Ive tried heat, pb blaster, nothing is working. any ideas? its on jack stands. Ive also tried lifting on the tie rod itself while hammering and still wont budge,
  8. Feb 23, 2025 at 2:41 PM
    slodoug
    Im done for today, put her back together and will stop by harbor freight and get a ball joint separator.
  9. Feb 23, 2025 at 6:23 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    With as many posts about ball joints I have witnessed I bought stock in them.
  10. Feb 23, 2025 at 6:27 PM
    MadNachos
    Just do more of what you are doing. A PB soak overnight goes a long way. If in doubt get a better tool. But a MAPP gas torch is what you want, it just transfers the heat better and burns hotter, a regular torch can cause too much heat soak so you don't really get the same results.
  11. Feb 23, 2025 at 6:31 PM
    Old green toyota
    Sacramento,CA
    Oil leaks
    I get parts at cost plus tax. Perks of working in a shop. I do have moog spares that travel with me. I was bailed out one day by someone with a spare LBJ. I hope to return the favor some day.
  12. Feb 25, 2025 at 2:08 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Nope. There's always been plenty of stock on these.
    Black97v6MT[QUOTED] likes this.
