lBJ bolt threads stripped, now what?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jbrandt, Aug 4, 2017.
  1. Aug 4, 2017 at 8:12 AM
    jbrandt
    jbrandt [OP] Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    (Updated on post 19)
    so, I'm overhauling/upgrading my front suspention with mid travel Kings, and total chaos UCAs, everthing is going relatively well, I get everything back together, and I torquing everything down. I'm doing the lower ball joint bolts that hold the Bj to the spindle and one of themstrips out.
    Not the bolt, the spindle threads!
    I wasn't even turning it very had and all of a sudden it starts getting easy to turn. Too easy.
    So just wondering about my options here. Anyone think a thread plug is a good idea, or should I just replace the whole spindle?
  2. Aug 4, 2017 at 8:12 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I would replace
    kgt0001 and Area51Runner like this.
  3. Aug 4, 2017 at 8:40 AM
    jbrandt
    Justin
    Yeah, def leaning that direction...
    Probably go oem for this part, unless anyone knows of a good "upgrade" part...
  4. Aug 4, 2017 at 10:52 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Replacing the spindle becomes a big issue because of the wheel bearing.
    If it is the threads for only one of the four lbj bolts, you might consider repairing it first. A lot simpler and cheaper.
    drr likes this.
  5. Aug 4, 2017 at 11:08 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    You could drill and tap it for the next size up. You'll have to clearance the hole in the lbj assembly as well for the larger bolt.
    Which bolt is it, inside or outside?
    SwampDeer likes this.
  6. Aug 4, 2017 at 1:56 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Any Good thread replacement will work just fine .
    If I fix head bolts it will be fine here.
    Are you sure it was not the bolt threads ??
    If you decide to change the spindle I would take the old one if you were not so far away
  7. Aug 4, 2017 at 2:21 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Drill and tap for sure with a larger stronger bolt.
    SwampDeer, Tacofart and Dalandser like this.
  8. Aug 4, 2017 at 2:44 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    The mounting pads are pretty thin. I would'nt chance it.
    I tried giving away a pair of 2004 4WD spindles a while back, but no one would pay shipping so in the scrap bin they went
  9. Aug 4, 2017 at 2:52 PM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
  10. Aug 5, 2017 at 11:20 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
  11. Aug 5, 2017 at 5:24 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Why so Tell me your theory .
    I have used thread replacements on things taking far more torque then these 10mm bolts.
    Always willing to learn new things
  12. Aug 5, 2017 at 5:25 PM
    anthony250f
    Anthony
    San Diego, CA
    These bolts are very sensitive. I wouldn't trust anything other than a new spindle
  13. Aug 5, 2017 at 6:11 PM
    License2Ill
    Ian
    Was that intended for me?
    Well these bolts don't need a tremendous amount of torque to begin with, 46ft-lbs, iirc? And the torque wouldn't be my concern.
    Especially off-road those bolts see a great amount of shear force. And without knowing the metallurgy of those heli-coils they may deform and warp under the stress. I don't know for sure if that'd happen....but that'd be my concern.
  14. Aug 6, 2017 at 8:23 PM
    jbrandt
    Justin
    I'm pretty sure it was the spindle threads. The bolts threads looked fine, but granted I was ina hurry to get it rolling again since it was in the way of my camper trailer and we were going camping the next morning!
    The bolt looked fine, with some metal shavings on the first thread (not part of the bolt), so maybe the threads are fine and maybe I just cross threaded it. Like I said, I was in a hurry and maybe just cross threaded the first thread. If that's the case maybe I'm okay, but after looking into how much of a PITA it can be to replace the spindle, I need to take a real close look at what is damaged, and haven't had that opportunity yet.
    It's the outer rear bolt, closer to the wheel, on passenger side.
  15. Aug 6, 2017 at 8:47 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    you could chase it first, then reassess. Tap is cheap enough to give it a shot.
    If you're young enough, you'll need it again sometime.
    FWIW: i wouldn't trust a helicoil there either....maybe permacoil (?) Whatever Toyota advised using for the Camry headbolt problem. I really don't advise that either w/o checking into fully but sure not heli.
  16. Aug 7, 2017 at 8:54 AM
    jbrandt
    Justin
    Is this what you're talking about (permacoil)?
    https://www.threadkits.com/perma-coil/
    Is so, what's the difference between that and a helicoil?
  17. Aug 7, 2017 at 9:30 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I really couldn't tell you but I was under the impression they were glued (epoxied) in. I may or prob. am mistaken about that. Both seem to be S.S. but Toyo. def. rec'd using the perma over the heli. for head bolts.
    That was in a case of trying to save a engine block that would have been very expensive to replace not to mention labor intensive.
    I believe I'd just pick up a used spindle and move forward w/o worry.
    jbrandt[OP] likes this.
  18. Aug 7, 2017 at 12:14 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Can't see any. All need to remember that helicoil or "any-coil" are one time deal. Even when you successfully put the bolt in, it can't be removed without the coil damage or removal. This solution is for desperate who wants to do cheap quick fix and pass on the problem on the next guy. Remember you will have to be able to torque the bolt to factory setting and even tho, helicoil'ed bolt will not have the same strength as the original one.
    For the best and permanent solution is to replace the faulty part. It is pita, but what is not. For temporary solution would be drill and tap the hole for the next size bolt (maybe close imperial size will work, I duno). Stay away form any coil unless you do it for someone who you do not care.
  19. Aug 13, 2017 at 12:57 PM
    jbrandt
    Justin
    Ok, so It's been a little while since I could get back under the truck, but it turns out that all 4 bolts were 30mm length, on both sides(!).
    So, ~6 years ago I replaced the LBJs and didn't think anything of the bolt lengths, I just reused the factory bolts, or at least what I assume were factory since I bought the truck when it was like 1.5 years old.
    So, all 4 inner bolts essentially had only 2 or 3 threads engaged for 6 years, and 40,000 miles, many road trips, wheelin, etc... In other words, I dodged a serious bullet with that one!! Damn.
    A trip to Oreily had me back with some m10x1.5 bolts because that's the size that fit their bolt sizing thing. I went with 10x1.5 even though I had read the size was 10x1.25, get home and, yeah, it reslly IS 10x1.25, so return those and head to Ace instead for some grade 10.9 bolts (30 and 40mm length) and a tap to chase the threads, some blue threadlock, and everything went back together flawlessly, and torqued to spec.
  20. Aug 14, 2017 at 3:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The threaded area on the OE bolts is a tad short of 1.25" long. The calipers say 1.23" or 31.25 mm. All 4 are the same length.
