lBJ bolt threads stripped, now what?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jbrandt, Aug 4, 2017.
  1. Aug 16, 2017 at 12:48 AM
    #41
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Loctite Threadlocker Red 271 is designed for the permanent locking and sealing of threaded fasteners. The product cures when confined in the absence of air between close fitting metal surfaces. It protects threads from rust and corrosion and prevents loosening from shock and vibration. It is only removable once cured by heating up parts to 500°F (260°C).
    Loctite Threadlocker Blue 242 is designed for the locking and sealing of threaded fasteners which require normal disassembly with standard hand tools. The product cures when confined in the absence of air between close fitting metal surfaces. It protects threads from rust and corrosion and prevents loosening from shock and vibration. Loctite® Threadlocker Blue 242 is particularly suited for applications on less active substrates such as stainless steel and plated surfaces, where disassembly is required for servicing.
  2. Aug 16, 2017 at 1:46 AM
    #42
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Red is considered permanent on fasteners smaller than 3/4". On 3/4" and larger it is considered removable and the equivalent to blue for these larger fasteners. Red usually needs heat to aid in disassembly once again on smaller fasteners.
    When I was in industrial sales I was trained directly by loctite / permatex.
  3. Aug 16, 2017 at 3:53 AM
    #43
    RysiuM
    Rysiu
    Cool, good to know. Now we are talking about LBJ bolts not railroad tracks :). 10mm is is almost half of 3//4 inch do red loctite big bold theory does not apply here. The bottom line use blue for LBJ job. Period.
    Now all need to be very careful about using OEM bolts for no OEM LBJ. The easy way to see a difference between aftermarket LBJ and OEM (besides greasing tip on some aftermarket parts) is the metal surface where these bolts go through. All aftermarket LBJ (including so famous MOOG) have these surface not finished (rough from the casting) and possible few mm thicker than OEM. For these LBJ 31.5 mm long bolts might be to short. OEM LBJ have both sides of each hole machined flat and to correct thickness so OEM bolts have enough thread to engage with steering knuckle.
  4. Aug 16, 2017 at 10:00 AM
    #44
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Red is far from permanent. I have coated the threads of my trans mount in that stuff multiple times and the bolts still come lose. Next step is tack welding the bolt to the mount.
  5. Aug 16, 2017 at 10:19 AM
    #45
    RysiuM
    Rysiu
    Both surfaces have to be clean from any oil and rust. The loctite is not a putty - the thinner layer of it between metal surfaces the stronger it is. Few times I was able to break bolts that were loctited (green or red).
  6. Aug 17, 2017 at 3:57 AM
    #46
    SwampDeer
    SwampDeer Active Member
    99 Tacoma 4x4
    3 inch lift.
    I just had a very similar problem. I drilled an tapped the hole one size larger. I have about 300 miles on it so far, some of those miles are off road. Every thing is holding up well so
    far.
  7. Aug 17, 2017 at 7:42 PM
    #47
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    Actually because of sleeve dowels the bolts see no shear at all.
  8. Aug 18, 2017 at 7:29 AM
    #48
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Same. However, I use Permatex, and that stuff, while red, says on the bottle "high strength", not "permanent". I guess red Loctite is different.
  9. Apr 3, 2022 at 10:48 AM
    #49
    Golfer
    Golfer Well-Known Member
    Does anyone know of a toyota flange bolt that's m12x1.25x32mm
  10. Apr 3, 2022 at 11:23 AM
    #50
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    for the lower ball joint? with or without the dust cover?
  11. Apr 3, 2022 at 11:41 AM
    #51
    Golfer
    Without
  12. Apr 3, 2022 at 11:54 AM
    #52
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  13. Apr 3, 2022 at 12:52 PM
    #53
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
