LBJ Concerns/Replacement Guide Recommendation
Discussion in '1st Gen. Tacomas (1995-2004)' started by dgshelto, Nov 8, 2017.
  1. Jan 5, 2025 at 9:12 AM
    Thoy
    Thoy Active Member
    2000 White Tacoma PreRunner 2.7
  2. Jan 5, 2025 at 9:14 AM
    Thoy
    Thoy Active Member
    They must have been on recall years 2001-2004. I’ve got a 2000 my LBJ’s are tight as drum. Should I be concerned especially when I’m not in the recall ?
  3. Jan 5, 2025 at 10:18 AM
    Pbfender15
    Pbfender15 Well-Known Member
    multiple 1st gens
    FWIW, I just did mine. The hammer method was 20 minutes of banging and frustration and I ended up going to HF for $15 for a puller after which it took 5 minutes. In this case proper technique beats brute force...
    My LBJs were on at least since 80k miles (when I got the truck) till now 180k miles. They showed no signs of play. PO may have changed them, but they may also have been factory.
    Moonrman likes this.
  4. Jan 5, 2025 at 9:36 PM
    JuniorVarsity
    JuniorVarsity I'm not a pickup truck guy. I have two.
    PacNW
    1999 Tacoma SR5 4x4, 2021 TRD Sport Access Cab
    I just did this as well. Autozone had a kit with a bunch of different pittman arm pullers, but that kit wasn't available. They had a "heavy duty" pittman that I rented/borrowed; worked pretty well. A couple of youtube vids also helped. Like so many wrenching jobs, the first time took forever; bet I could do it in 1/3 the time if I tackle it again.
    I know this thread is old, but for anyone who stumbles across it, be sure to check out the excellent thread about LBJ bolt torque (it's entitled something like "everything you ever wanted to know about lower ball joint bolts"). TLDR: there are several different types of bolts; torque values vary, and you really don't want to pork it away.
  5. Jan 5, 2025 at 9:49 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Tie rod and ball joint puller tool part numbers are in this video:
    https://www.youtube.com/watch?v=bfLvtEnX9qk
    You don't have to buy a big kit, I just have the two of them and they work well - no hammering on the spindles.
  6. Jan 6, 2025 at 7:44 PM
    Thoy
    Thoy Active Member
  7. Jan 6, 2025 at 7:46 PM
    Thoy
    Thoy Active Member
    If they had zerk grease fittings they were NOT OEM.
