LBJ Failure
Discussion in '1st Gen. Tacomas (1995-2004)' started by time623, Aug 21, 2017.
  1. Aug 21, 2017 at 7:40 PM
    time623
    time623 [OP] Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Great way to start off the first full week of classes, can only be thankful I was going slow on a side street, not on a highway. Especially since I've been making a 60 mile highway commute every week this month.
    Already got it towed to a shop, don't have time for fixing this with class. Anyone know if the differential was likely to be damaged in this? Looked like the CV got ripped out of the diff as the tire collapsed..
    Also..Dont mind the awful tire wear.. Alignment and new tires were coming very soon haha
  2. Aug 21, 2017 at 7:48 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    damn - glad nobody was hurt. sucks.
  3. Aug 21, 2017 at 8:37 PM
    Kittenmittens4U
    Kittenmittens4U Well-Known Member
    Sam
    Denver, CO
    98 Xtracab TRD 3.4l Evergreen Pearl
    Airaid MIT w/deckplate mod Grey wire mod 265/75/r16 Duratracs 2.5 Extended Travel King Coilovers Built Right Fabrication Uca's OME Dakars W/AAL and 10' Bilstein 5125's Toytec U bolt flip and extended brake line.
    How many miles are on the truck? Did you hit a pot hole or anything? That's one of my worst fears in my 98, I plan on doing mine when I finally save up enough for new shocks ( so close one or two more paychecks!)
  4. Aug 21, 2017 at 8:41 PM
    time623
    James
    AZ
    245k miles, no pot holes or anything.. Was approaching an intersection going maybe 5-8 mph on a flat road and it just collapsed.
  5. Aug 21, 2017 at 8:45 PM
    Kittenmittens4U
    Sam
    Denver, CO
    Wow that's terrible, I'm glad that the conditions posed little threat to injury and I hope you/ everyone is okay.
  6. Aug 21, 2017 at 8:52 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Quite happy you are OK.
    From your thread title "LBJ Failure" I thought you were talking about the Great Society...
  7. Aug 22, 2017 at 8:21 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Seen this happen time and time again. And that's a LOT of miles on the original LBJ. These OEM LBJs can last a long time, but you should really be changing them out every 100k. It's actually quite easy to do, you can rent a tie rod and pitman arm puller from auto parts stores for free. All you need are about an hour or so of free time. MAKE SURE the shop replacing your LBJs use OEM parts, and you should just need a new CV at a minimum (I would recommend a Napa Lifetime CV to save some coin). Maybe a new diff seal on that side as well.
  8. Aug 22, 2017 at 8:49 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
  9. Aug 22, 2017 at 2:30 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Does that apply for all Gen 1?
  10. Aug 22, 2017 at 2:33 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  11. Aug 22, 2017 at 2:34 PM
    eon_blue
    Azusa, CA
    Glad you're okay. I'd wager a bet that your alignment was so off because the ball joint wasn't functioning properly, surely there must have been warning signs? Popping sounds when turning, steering not acting right (wanting to pull it's own way), etc.? Unfortunately, this is one of those things that us 1st gen owners have to be diligent on (checking the LBJs) regularly.
    PROseur likes this.
  12. Aug 22, 2017 at 5:21 PM
    PROseur
    Pussy
    What is the method for "checking?"
  13. Aug 22, 2017 at 5:27 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Here's one way. Although toyota's measurement for unacceptable free play is almost impossible to see. This is a LOT of play.
    https://youtu.be/hBbCVirmQ44
  14. Aug 22, 2017 at 5:29 PM
    PROseur
    Pussy
    So what is happening there?
    Use jack to lift truck and then put hands on wheels and move it around?
  15. Aug 22, 2017 at 5:29 PM
    eon_blue
    Azusa, CA
    The method @thunderone posted above is the same link I usually refer people to. You don't have to have your truck on a lift, you can just jack up one side at a time using your bottle jack.
    PROseur[QUOTED] likes this.
  16. Aug 22, 2017 at 5:40 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yes. You could also put a large pry bar between the lower control arm and the ball joint bolts, pry up and look for play. I cant find a video of this anymore. Driving me crazy. It was at a Toyota dealership and one of the service guys was talking about it. I just can't find the video. I would prefer to do it this way as opposed to the tire shake test.
  17. Aug 22, 2017 at 7:58 PM
    time623
    James
    AZ
    There were no sounds or anything. I might have noticed my steering not acting right, if my power steering wasnt already going out. Shop already told me I needed a new rack and pinion, so I might have just associated any problems arising from the ball joint to the rack and pinion...
    eon_blue[QUOTED] likes this.
  18. Aug 22, 2017 at 8:30 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Found the other video! See below.
    muddog67 likes this.
  19. Aug 22, 2017 at 9:07 PM
    PROseur
    Pussy
    Thank you SO much !!!!!
    Vehicle has to be on lift to do it or can I try it on the ground ?
    ThunderOne[QUOTED] likes this.
  20. Aug 22, 2017 at 9:31 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Maybe that's why the tire was wearing unevenly?
