LBJ Failure
Discussion in '1st Gen. Tacomas (1995-2004)' started by time623, Aug 21, 2017.
  1. Aug 22, 2017 at 10:33 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I'm not a betting man, but I'd say you would still have to check the play with the wheels hanging off the ground. Otherwise, in order to tell if its loose you'd have to find some way to push it down, and not up. With the wheel hanging down, it's resting at the bottom of the LBJ, so you can lift up on the LBJ or the wheel itself to check for play. if it's on the ground, it'll be as far up as it can go, resting at the very top of its travel, so you can't really check it. If that makes any sense. Had to watch the vids again to make sure.
    PROseur[QUOTED] likes this.
  2. Aug 23, 2017 at 4:14 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Posts like that scare the shit out of me. My truck has a bit over 318k miles. I have original LBJ in my truck, meaning they were installed in Fremont factory in 1995. I had them checked by four independent places (Toyota service in Elk Grove, American Tires shop, Wheel alignment place and finally Toyota service on Poland). All gave me green light. I'm checking them regularly and they are still like new. How much longer can they go? I have a spare OEM set on the shelf waiting to be installed, but only after I will see my original start going bad.
    I suspect that my truck was built as a demo model using all hand picked the best parts of the lot :thumbsup:
  3. Aug 23, 2017 at 5:30 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    If you are good about checking em, then roll on! *now has "Roll On" by Alabama stuck in head*
    PROseur likes this.
  4. Aug 23, 2017 at 12:25 PM
    TeeYoda
    TeeYoda Well-Known Member
    PNW
    2003/2025 Tacoma sr5 4x4
    For me, LBJ's are like a maintenance item. With 200,000 miles on your original ones, I'd change them out even if they feel o.k. just to be safe. It's an easy enough job. No use tempting fate. And especially with LBJ's, OEM is the only way to go!
    detrio007 likes this.
  5. Aug 23, 2017 at 12:48 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    How much are oem ones ? I have 210k on my original ones
    I will test them out this weekend
  6. Aug 23, 2017 at 12:59 PM
    labrador01
    labrador01 Well-Known Member
    Kyle
    Northern IL
    2015 Tacoma
    I'm curious about the Napa axles vs cvj's. I need to do both my fronts, I would like all the opinions I can get. Not really interested in rebooting my oems.
  7. Aug 23, 2017 at 1:11 PM
    RysiuM
    Rysiu
    Do you need to to alignment after LBJ replacement OEM to OEM ?
    MagicMexican likes this.
  8. Aug 23, 2017 at 1:35 PM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    Good question. I am curious about this, too.
  9. Aug 23, 2017 at 1:43 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    No.
  10. Aug 23, 2017 at 2:22 PM
    labrador01
    Kyle
    Northern IL
    2015 Tacoma
    I'd recommend an alignment after any ball joint replacement but that's just my opinion.
    98tacoma27 and PROseur like this.
  11. Aug 23, 2017 at 2:32 PM
    TeeYoda
    PNW
    I paid about $130 for the pair for my 2003. Ordered them from Camelback Toyota. I think there is TacomaWorld discount code for Camelback, so you may be able to get them cheaper. Also, you should get an alignment after any front suspension work.
  12. Aug 23, 2017 at 2:34 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Ive seen aftermarkets fail in less than 10k miles on the 4runner forums.
    TeeYoda likes this.
  13. Aug 23, 2017 at 2:39 PM
    JayRolla
    Colorado Springs
    If the ball joint was loose when they did the last alignment than you would need to get another one. If it was solid before it loosened up you should be okay.
    ThunderOne likes this.
  14. Aug 23, 2017 at 2:40 PM
    JayRolla
    Colorado Springs
    Mine tested solid and had no play right before they failed. I recommend changing every 100k miles.
  15. Aug 23, 2017 at 2:47 PM
    #35
    MagicMexican
    Alejandro
    Pueblo, Colorado
    Aftermarket Wheels
    I just ordered mine this morning, from Camelback and they were $220 for both including bolts.
    PROseur likes this.
  16. Aug 23, 2017 at 2:48 PM
    #36
    PROseur
    Pussy
    Yikes!!!!
    In that case testing then is useless!!!!
  17. Aug 23, 2017 at 2:53 PM
    #37
    gbollom
    gbollom Well-Known Member
    Weatherford Tx
    01 xcab TRD 4x4 5spd
    Why is everyone so scared of using anything other than OEM? LOL get a grip guys, I'm willing to bet 99% of people with premature failures had an underlying cause
  18. Aug 23, 2017 at 2:54 PM
    #38
    MagicMexican
    Alejandro
    Pueblo, Colorado
    Aftermarket Wheels
    Yeah, wear. Do some searching on here, there are posts with cross-sections of the LBJ's showing exactly why OEM are better and last longer.
    PROseur likes this.
  19. Aug 23, 2017 at 2:57 PM
    #39
    JayRolla
    Colorado Springs
    I literally had an alignment right before they failed. They said all ball joints and tie rods were solid.
  20. Aug 23, 2017 at 2:58 PM
    #40
    gbollom
    Weatherford Tx
    I've read a bunch of them and yet to see any evidence to actually support this, what i have seen is a ton of regurgitated folk lore
    98tacoma27 likes this.
