LC 9.5 axles
Discussion in 'Solid Axle Suspension' started by Broke Okie Ty, Dec 13, 2021.
  1. Dec 13, 2021 at 1:20 PM
    Broke Okie Ty
    Broke Okie Ty [OP] Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
    Would there be any interest in a pair of toyota axles. The axles aren't built but I have all the parts to do it. I found a really good deal on some diamond 609s and I'm changing directions with axles. If I build them, I'd want around 4k-5k. What do you guys think?
    Front
    Fj60 rear housing
    LC9.5 diff 5.29s open
    Fj80 shafts, knuckles balls, hellfire knuckles
    Mini truck spindles with ifs hub swap
    New 13" rotors and 14wa calipers
    Chromo asin hubs
    Rear
    Centered SF fj80 rear housing
    Nitro chromo shafts
    Fj80 full float ends
    New fj80 rear brakes
  2. Dec 13, 2021 at 1:24 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    @Digiratus, you want that rear prolly if the width is right
    Digiratus likes this.
  3. Dec 13, 2021 at 1:39 PM
    Broke Okie Ty
    Ty
    I could make the rear from 61-64"ish. The front would be around 64.5-65"
  4. Dec 13, 2021 at 1:57 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I only need the rear. What are looking to get for it? Where is it?
    Buttskevin21 likes this.
  5. Aug 31, 2022 at 9:09 PM
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    Hmm Would be nice to have a full float and matching 9.5 front and rear too
    Naveronski likes this.
