LC Engineering Header Kit for 2TR with Stock Exhaust - thoughts?
Discussion in '4 Cylinder' started by NTX Taco, Feb 7, 2020.
  1. Feb 7, 2020 at 10:33 AM
    NTX Taco
    NTX Taco [OP] Member
    Andrew
    Dallas, Texas
    2014 Tacoma SR5 4x4 2.7L 4A
    American Outlaw Rangers, 265/75/16 KO2's, KC Apollo's, Smittybilt Grille
    After doing some research on the forum, it seems like personal reviews from everyone are generally really positive with the LC Engineering Header for the 2.7. My purpose for buying one would simply just be the best way to get a little more torque available down low in the rev range, which the header seems to accomplish.
    This is where I need help. My concern is the noise level of adding a header.
    If I were buy the LCE header and keep everything else bone stock on the car, is there anyone who can share what the drone/noise levels are like in-cabin? I reached out to LCE, and they referenced a video that has the header with an aftermarket exhaust that I know will simply be too loud for my taste.
    I'm expecting a little more noise, which is fine with me. However, I want to be able to drive along the road and have a conversation with someone, without the conversation drowning out to the engine droning and buzzing as I push/stay on the gas pedal.
    If anyone has any experience or videos they could share, that would be a TREMENDOUS help to me and my future purchase!
    Misfit likes this.
  2. Feb 7, 2020 at 2:38 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    I dont have one, but I really doubt putting that header on it will make it louder without changing the muffler.
    The factory exhaust manifold isnt the big cast iron style that used to come on cars that would block out a little valve noise or whatever. Its looks like a header as well compared to the old style cast iron type.
    Hooligans and NTX Taco[OP] like this.
  3. Feb 7, 2020 at 5:18 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Im running the lce header on my 2.7 with the stock catback exhaust and it did not make it any louder
  4. Feb 10, 2020 at 8:07 AM
    NTX Taco
    Andrew
    Dallas, Texas
    Thank you both.
    BassAckwards, would you say you've noticed any sort of gain in your low end power once you installed the LCE header? Even with running your stock catback exhaust?
  5. Feb 10, 2020 at 8:51 AM
    BassAckwards
    I would say there are some low/mid range gains to be had. I remember drivability being a little better after installing the header. Didnt seem to struggle as much going up the hills where i live. I have the 5spd but i think an equal length setup is a great addition for all of these 4 bangers
  6. Feb 10, 2020 at 10:06 AM
    NTX Taco
    Andrew
    Dallas, Texas
    That's exactly what I'm looking to accomplish. Just a little extra power to get me over some hills/long grades without needing to take deep stabs at the throttle to keep my momentum going. Especially if cruise control is on.
    Appreciate it!
  7. Mar 11, 2020 at 1:14 PM
    Misfit
    Misfit Well-Known Member
    IL
    2017 SR 2.7L 4x4 5MT
    I can second this, I have it installed with factory exhaust. Almost no audible change, maybe a slight rumble if you heard it in a garage setting. Power gain is noticeable down low, easier to maintain speed and less lugging in the higher gears. Go for it!
  8. Mar 13, 2020 at 8:17 AM
    Kingbee14
    Kingbee14 Member
    Scott
    2017 Tacoma SR5 Access Cab
    No change in MPGs? Improvement? Worse?
  9. Mar 13, 2020 at 8:50 AM
    Early B.
    Early B. Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
    No change in MPG.
  10. Mar 14, 2020 at 5:20 PM
    Beach Ghost
    Beach Ghost Well-Known Member
    T
    2013 Tacoma Reg Cab 4x4
    265/75/16 Falken Wild peak AT Tinted windows Rear differentel breather mod Bilstein 5100 rear LCE Header AFE Dry Filter Master Flow super 44 Air pump filter mod Intermittent wipers Hertz 6 1/2 front speakers TRD shift knob Curt rear trailer hitch Trailer wiring kit Front steel Shackle plate Warn shackles front and rear Neoprene seat covers
    No change in mpg
  11. Mar 17, 2020 at 3:33 PM
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    No change in mpg. No noise change to me. Butt dyno feels slight more umph.
    BassAckwards likes this.
  12. Mar 19, 2020 at 10:46 AM
    Plucky was his name
    Plucky was his name Well-Known Member
    Carl
    Central East Texas
    2007 Reg Cab Taco 4x4 5-speed manual
    ARB Front Bumper, Wet Oakle Seat Covers, Aftermarket Stereo, OME suspension with Heavy Duty Dakar Leaf Springs
    My observations, OP, may be coming a little late, but the biggest difference pre/post LCE Header was drivability on the Interstate. Of all different driving situations this was by far the most noticeable.
    I’ve had my header for about a year now, along with the OME lift that I did at the same time, and I no longer ever have to downshift to 4th gear at any point on any drive between Houston and Dallas on I-45. Before, when I was at stock height and header, sometimes I would if I was driving into a stiff headwind.
    But now, and with 3+” of lift, I do not. My truck feels no faster, but it just “holds” its speed better. That’s about the best way I can describe it.
    Oh, and I have a little extra exhaust sound at around 3,000 rpm when accelerating. It isn’t loud, not even a growl, more like an increased resonance.
  13. Apr 28, 2020 at 11:12 PM
    trustyrusty436
    trustyrusty436 Well-Known Member
    2018 Tacoma, auto, 2.7, RWD Access cab, long bed, Utility model
    LCE exhaust header, AF Dymanics CAI, MagnaFlow cat back
    The LCE header is good for about 25hp and 20 ft lbs of torque, it is very noticeable, well worth putting on your 4 banger. There is a slight increase in exhaust noise.
    Charlie Bravo likes this.
  14. May 4, 2020 at 5:56 AM
    KevinC
    KevinC Well-Known Member
    Kevin
    2017 SR5 Quicksand Tacoma
    What about interstate speeds when cruising 70mph and above? I appreciate the answer from the 2nd gen 4banger dude above you, but his setup is different and his rig significantly lighter. What about you?
  15. May 4, 2020 at 6:52 AM
    Beach Ghost
    T
    I have the LCE header with a flowmaster super 44 muffler and stock exhaust. For me it has eliminated the jumping between 4th and 3rd on hills,pulls harder from a standstill and sounds pretty good.
  16. May 13, 2020 at 11:08 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    Got a video by any chance? I've looked up so many exhaust videos of the 2TR and they all sounded like Civics to me which I dont want.
  17. May 14, 2020 at 1:00 AM
    Beach Ghost
    T
    I will try and record one in the nex couple days. I like the flowmaster for the performance along with the LCE Header the sound well let's just say it's hard to get rid of the 4cyl "Civic" sound you will always have that sound somewhat from a 2.7 4cyl
  18. May 17, 2020 at 7:12 AM
    Beach Ghost
    T
  19. May 17, 2020 at 7:28 AM
    KevinC
    Kevin
    Did you just try to post that video?
  20. May 17, 2020 at 7:28 AM
    Beach Ghost
    T
    Here you go
    yes can't get it to load
