LCA -- Adjustable Camber bolt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Peru, Aug 21, 2014.
  1. Aug 21, 2014 at 11:01 AM
    Peru
    Peru [OP] Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    Well after 130K and the fact that my ball joints are both leaking some grease i figure I might as well replace bushings, joints and with all the issues there have been with the camber bolts i figure id replace those too. I dont want to get in there and find out I need to replace and since I am here in MX its not a case where I can just order some up.
    I guess I can jack the truck up and loosen them up to see if the are not too stiff and apply a generous amount of anti-seize on reassembly. It would be about $200 for all 4 bolts.
    What says the experts. Some details below.
    1. I live in a area which is dry most of the year but swamped for 3 months. Regularly i drive through 8in of water if not more.
    2. They have been totally submerged.
    3. 130K miles
    4. pot-hole infested roads every day all day long
    5. not easy to source parts unless i go to the dealership which = more $$
    One other question -- at how many miles is everyone replacing the rear pads. mine are from the factory
  2. Aug 21, 2014 at 5:28 PM
    Peru
    Jonathan
    Redmond WA
    none
    bump!!! anyone?
  3. Aug 21, 2014 at 5:36 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Mark them for position, then go under your truck and test one out; If they move - they're fine! :)
    ... sounds like you've already decided to replace them to spare any headache though...
  4. Aug 21, 2014 at 5:37 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  5. Aug 21, 2014 at 6:17 PM
    Peru
    Jonathan
    Redmond WA
    none
    well when I see so many people talking smack about those bolts I get proactive and want to replace everything but at $200 for 4 of them from NAPA and since I just dumped about $3K on dental work and new Blistines Id like to hold on to my $$.
    Looks Like kenLyns has given me a good option. saving $60 might push me in that direction. I like being able to grease the darn things, but if like you said they move which = they are OK then I am going to just grease them up and re-install when I take the LCA off.
    Thanks for the info
  6. Aug 21, 2014 at 6:49 PM
    Peru
    Jonathan
    Redmond WA
    none
    ok just so I am on the same page or better said the correct page as everyone else. These bolt/cam assemblies are not wear items. They get replaced when they seize, or am I missing something? They have be on there for 130K and if they loosen up then they are good for another 130K
  7. Aug 21, 2014 at 6:57 PM
    Peru
    Jonathan
    Redmond WA
    none
    Interesting -- cambolts are the exact same ones sold by rockauto under the raysbestos brand as the NAPA ones just cheaper at rockauto
    NAPA
    Rockauto
  8. Aug 21, 2014 at 7:02 PM
    KenLyns
    Belly of the Beast
    ^Probably the same factory in China cranking them out and putting them in differently-branded boxes...
  9. Aug 21, 2014 at 7:38 PM
    Peru
    Jonathan
    Redmond WA
    none
    I am just going to plan on changing them. For $150 I am not going to screw with the old ones. Too much aggravation
    Thanks guys for all the guidance. It is much appreciated. Once again TW saves me some serious $$$$
