LCA Bushing Replacement
Discussion in 'Arizona' started by bkrdave36, Oct 25, 2013.
  1. Oct 25, 2013 at 4:18 PM
    bkrdave36
    bkrdave36 [OP] Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Daystar 3 inch lift, BFG All Terrain KO Tires, Avid Light bar and step rails, custom made bed rack with Tepui Ayer Rooftop Tent, BHLM, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod,Rigid Knockoff LED Floodlights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper. thats it so far .... to be continued!
    HEy All ...
    My 06 DCSB is in the shop right now.
    Mechanic says it needs all three new U Joints on the Drive line and the LCA Bushings are split( ?)
    Why I took it in ....
    At about 35 mph, 45 mph, and above 50 mph I would get a vibration in the truck.... nothing violent, but enough to think I had an out of balance tire or something. Through some detective work I ruled out any wheel issues because if it was a wheel issue the vibratrions wouldnt stop when I take my foot off the gas. Right?. Also, sitting stopped in Neutral, I ran the motor up and down a few times and everything was ok, no vibes. So I figured trans or driveshaft or rear end.
    So here is my question. I was planning on replacing my Daystar lift kit on stock shocks/struts with a better system in the spring with my tax refund money. (Adjustable shocks, ICON UCA, etc.) Mechanic says he can only get the whole LCA assembly and not just the bushings. Is there a relatively inexpensive repair for this that will hold me over until next spring, or is this something that I'm gonna have to break out the credit card and should get done right away?
    I'm guessing the driveshaft u joints is 99% of my vibration issue, and the LCA is just a lucky find by the mechanic while trying to figure out the vibration issue.
    Any help would be appreciated.
  2. Oct 25, 2013 at 5:49 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    might have factory LCA's for sale here in a bit.
    Ill PM you if in fact I get rid of them and maybe we can work something out.
  3. Oct 25, 2013 at 6:23 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Hmu on price as well
