LCA Bushings are squeaking like crazy...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kwikvette, Sep 23, 2019.
What would you do in my situation?
  1. Replace with OEM bushings
    52.6%
  2. Grease/Lube (provide your lube choice, and how to in your reply)
    47.4%
  1. Sep 23, 2019 at 5:21 PM
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    I replaced my lower control arm bushings with Whiteline poly bushings about 3 months ago.
    I know with rubber, you just install and enjoy.
    Poly requires lubricating,etc.
    When I took everything apart, I used all the grease provided in all the required areas and reassembled everything.
    Steering became, and still feels nice and tight. Alignment is good. These are things I expected with new LCA bushings.
    Problem is, everything squeaks like a mother fucker, even when I lightly press the brake if the vehicle is moving at even 1/2mph.
    I'm contemplating removing my LCA's and going with OEM bushings, unless someone has a good way to get in there and lubricate the Whiteline bushings that are installed? And also, what type of lubricant lasts the longest?
  2. Sep 23, 2019 at 5:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Speedytech7 tagging you first brother, since I forgot you in the LT thread :rofl:
  3. Sep 23, 2019 at 5:23 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    silicone spray
  4. Sep 23, 2019 at 5:24 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Grease em up real nice and goopy with some SuperLube. They'll be more maintenance than rubber bushings from a noise POV
    G59 likes this.
  5. Sep 23, 2019 at 5:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Let me add; I've tried the PBlaster dry ptfe stuff and it didn't quiet anything down.
    I also tried some dry Teflon stuff.
  6. Sep 23, 2019 at 5:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So you're suggesting I take it all apart again :annoyed:
  7. Sep 23, 2019 at 5:34 PM
    BillsSR5
    bill
    2014 SR5
    if those didn't work no sense trying other lubes, if they worked any should of been a notable difference in the sqeak
  8. Sep 23, 2019 at 5:35 PM
    Speedytech7
    Yup, they have to be greased up super goopy initially. Like downright making a mess with the stuff in between every part.
    G59 and Running Board Man like this.
  9. Sep 23, 2019 at 5:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    FML
    Good thing is I still have an extra set of LCA's...I'd just hate to pull everything apart again...grrr
  10. Sep 23, 2019 at 5:45 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Try this:
    https://www.amazon.com/Prothane-19-...=1569285678&sprefix=prothane+1,aps,185&sr=8-3
    Expensive, yes, but worth it. It's the same type of grease that comes in the tiny "ketchup packages" when you get new bushings. It's thicker than hell and ultra, mega, super duper water proof. So much that it's actually really hard to get off your hands when you're done and trying to clean up. This is key because that means it'll stay put wherever you put it and not weep or melt away and certainly wont wash off during rainy season or submersion. It's so thick that it's actually hard to squeeze through a standard grease gun BTW.
    Here's a smaller QTY if you want to test before you blow $45 on a tube.
    https://www.amazon.com/Prothane-19-...RXNAMQ50VM2&psc=1&refRID=N3ZKMV9XMRXNAMQ50VM2
    Kwikvette[QUOTED][OP] likes this.
  11. Sep 23, 2019 at 5:46 PM
    eon_blue
    Azusa, CA
    Are the poly bushings the ones that move in the control arm unlike the OEM rubber bushings? Or am I thinking of the main eye leaf bushings vs poly instead?
    Just curious cause if it's the same as the leaf spring ones then the right grease makes all the difference. Some kind of silicone grease like Superlube, Energy suspension or Daystar grease will be needed.
    Too bad they aren't greasable like the leaf bolts can be, sounds like they gotta come apart again
    My oem rubber ones quiet down just with some silicone spray but I guess that won't be sufficient for the poly bushings
  12. Sep 23, 2019 at 5:48 PM
    GHOST SHIP
    GHOST
    I use Superlube for most things on the truck, but for problem areas that I don't want to or cant get to easily enough to maintain as often, I like to use Prothane Super Grease (linked above). Totally different animals and each has its place, IMO.
    eon_blue[QUOTED] likes this.
  13. Sep 23, 2019 at 5:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Without side tracking too much; is this the same stuff you told me about on the phone?
    I want to tackle the squeak in my LCA's first, especially since some of the noise was tamed from the rear when I put Red N Tacky on the plastic discs/pads between my leaf springs.
  14. Sep 23, 2019 at 5:54 PM
    GHOST SHIP
    GHOST
    I mentioned Superlube (thinner viscosity) when we spoke. I rarely mention Supergrease (thicker, greasier) to people because it's one of those things I rarely pull out of the toolbox. Superlube does the trick 99% of the time for me anyway.
  15. Sep 23, 2019 at 5:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ordered Supergrease specifically for the Whiteline's; I figured I'll purchase OEM bushings for the extra LCA's and take apart the one's that are on my truck, and lube with Supergrease.
    If I fuck something up, because murphy's law, I'll have a set to go back on with new OEM bushings. If all goes well, I'll have LCA's to sell that are ready to go.
  16. Sep 23, 2019 at 5:58 PM
    eon_blue
    Azusa, CA
    And I'll probably end up buying them rather than dealing with removing my old ones lol
  17. Sep 23, 2019 at 5:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Lol it's been so long I forgot that you're on borrowed time with yours!
    How do you not have uneven wear in your tires :rofl:
  18. Sep 23, 2019 at 6:00 PM
    eon_blue
    Azusa, CA
    I really don't know if they're bad or not, my alignments are always good they just make a lot of noise. Might just be the first sign of them going IDK.
    Never had the alignment techs tell me anything about them but next time I'll ask them what they think
  19. Sep 23, 2019 at 6:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just when I thought the list was growing smaller -
    -Sliders
    -Front bumper OR hidden winch
    -Rear shock relocation
    -Winch
    and that's all that was left for my truck.
    Now I've got to tackle something I've done before already.
    GHOST SHIP likes this.
  20. Sep 23, 2019 at 6:07 PM
    eon_blue
    Azusa, CA
    Your list is a lot more fun than mine
