LCA Bushings are squeaking like crazy...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kwikvette, Sep 23, 2019.
What would you do in my situation?
  1. Replace with OEM bushings
    52.6%
  2. Grease/Lube (provide your lube choice, and how to in your reply)
    47.4%
  1. Sep 23, 2019 at 6:08 PM
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    Mine can be funner if I has SUPER WHINEY SOUNDING PULLY THING in lieu of my intake manifold...
  2. Sep 23, 2019 at 7:40 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Do it right and replace with OEM bushings.
    I did mine in a few hours using Timmy the tool mans video for reference...
  3. Sep 23, 2019 at 10:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So I just wanted a 'majority' vote kind of thing; I replaced the LCA's and bushings myself so I'm sure doing it again will be faster and easier.
    I'd like to ask what you mean by doing it "right" though? Are the OEM bushings superior to after-market poly bushings?
    I'm all for spending more on whatever is better, as I've already done that enough in this truck already.
  4. Sep 23, 2019 at 10:28 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Sorry, not to imply you did it wrong. Over the last few years it occurred to me that aftermarket may not be what’s best. OEM stuff just lasts. That said, I have Camburg Uniball UCA’s with poly bushings and they are fine. (And greasable).
    I did my lowers with OEM rubber bushings. My shackles are OME poly, and do require greasing from time to time. They will howl if not...
  5. Sep 24, 2019 at 2:21 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    Since you have them installed try everything.
    My 2003 was squeaking, fairly new 1-3 yr old new lowers, i shot them with wd40 dry lube -then soon after- just fluid filmed them. They’ve been quiet for awhile now. Worth a try, yep its a bit messy but it worked for me for the time being.
  6. Sep 24, 2019 at 10:46 AM
    eon_blue
    Azusa, CA
    I think the difference with poly bushings though like the ones he has installed is that they need a specific kind of silicone based grease inside the bushings to function quietly. The OEM rubber bushings you can just hit with some lubricant spray and it'll work to quiet them down for awhile. I do the same thing with mine.
    Makes me lean toward just replacing them with rubber ones again when the time comes rather than going with poly. After my experience with leaf spring bushing noises I really don't have much faith in poly bushings.
  7. Sep 24, 2019 at 11:04 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Going to be tackling them tomorrow or the day after; I've mentally given up going wheeling anywhere on my days off so I may as well be productive.
  8. Sep 24, 2019 at 11:08 AM
    eon_blue
    Azusa, CA
    Given up why?
  9. Sep 24, 2019 at 11:25 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Given up for my days off that is; I work 65+hours a week and have Wednesdays and Thursdays off.
    If I have nothing major to do IE big errands, I'll take that opportunity to go wheeling, or camping, or a short trip.
    However, since I really want to get rid of this noise, pulling apart my lower front end is considered a "major thing". When things should go easy, they usually don't.
    eon_blue[QUOTED] likes this.
  10. Sep 24, 2019 at 11:26 AM
    eon_blue
    Azusa, CA
    Ah OK I misunderstood, thought you were giving up on wheeling lol.
    Kwikvette[QUOTED][OP] likes this.
  11. Sep 24, 2019 at 11:27 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I know it's legal in CA, just stay off of it :rofl:
  12. Sep 24, 2019 at 11:30 AM
    eon_blue
    Azusa, CA
    :rasta:
    those days are long gone, never liked the stuff anyway lol
  13. Sep 24, 2019 at 4:22 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    I didn't read through the whole thing, however if you aren't torquing the lca bolts down after the truck is settled to ride height you could try that along with the heavy lubing.
  14. Sep 24, 2019 at 4:41 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I run Energy Suspension poly bushings and they've never once squeaked. Just sayin'... :boink: :D
    Just grease them. I use this red crap that's been in my garage for ages. When it was a daily driver + occasional off-road, I went 6 years :anonymous: without doing a single thing to them and they never squeaked. I took them out when I did my Kings a year or 2 ago, they were still perfectly fine, so I greased them up and threw them back in.
  15. Sep 24, 2019 at 5:52 PM
    #35
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yep.
    Just the same way I torqued down the front coil overs and rear leaf pack.
    I've read a lot of other threads where people are getting the same squeaking I get from poly bushings, so I was on the fence of just going with OEM or taking my current setup apart and greasing it all up with something different.
    With that being said, I'm not wheeling these next days off and instead, performing some noise-control.
    RedManRocket[QUOTED] likes this.
  16. Sep 24, 2019 at 5:56 PM
    #36
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I recently replaced my lca bushings with whiteline (on my second gen) and I think I hate them. They’re hard to keep lubed and everything has to come apart to lube them. It is legitimately making me consider just buying some performance aftermarket lowers for zerks.
    Kwikvette[OP] likes this.
  17. Sep 24, 2019 at 11:26 PM
    #37
    Kwikvette
    Fresno County
    4 run, 2 don't
    OEM bushings are $73/ea.
    Rockauto has OEM replacements that vary from $11 to $15/ea.
    Plan here is, replace the bushings on my extra LCA's and swap in the LCA's with rubber bushings and remove the LCA's with Whiteline's.
    Can't decide what brand to go with as they're all listed as 'Daily driver'.....
    https://www.rockauto.com/en/moreinf...+gxQm1UVae8W9XJ+oDgRb/VaO2ryj+0knoqJKDpx3o3k=
    https://www.rockauto.com/en/moreinfo.php?pk=10920972&cc=1375343
    https://www.rockauto.com/en/moreinfo.php?pk=389984&cc=1375343
  18. Sep 25, 2019 at 12:00 AM
    #38
    eon_blue
    Azusa, CA
    I would order the actual Toyota ones, no telling how iffy the rubber quality may be on the aftermarket brands even if they claim to be OEM equivalent. Don't wanna have to replace them all over again.
    See how much they are over on Toyotapartsdeal.com...they usually have pretty good prices. They pull from the cheapest parts dept in their network (makes returns a pain if you have to return something). Ive used them several times though and always had good luck. That or Camelbacks site
  19. Sep 25, 2019 at 8:24 AM
    #39
    Kwikvette
    Fresno County
    4 run, 2 don't
    $52/ea...so that's over $200 for 4 bushings if I go OEM.
  20. Sep 25, 2019 at 8:54 AM
    #40
    jbrandt
    Justin
    Yeah, I definitely heard the same thing, that poly bushings and uniball UCAs squeak all the time. I don't really know what I did differently, but mine have never squeaked.
