LCA Bushings are squeaking like crazy...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kwikvette, Sep 23, 2019.
What would you do in my situation?
  1. Replace with OEM bushings
    52.6%
  2. Grease/Lube (provide your lube choice, and how to in your reply)
    47.4%
  1. Sep 25, 2019 at 4:17 PM
    #61
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    Steering rack? you mean CV? I've orientated my front cam bolts to pull out the front and the rear cam bolts to pull out to the rear.
  2. Sep 26, 2019 at 4:39 PM
    #62
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Well for me I had to loosen the steering rack to move it up a bit so I could slide the cam bolts out from the rear part of the LCA toward the back of the truck in order to get them out. That's how i've known to do it and what i've read a lot of others do too.
    Never thought about trying to put them in another way.
    Kwikvette[OP] likes this.
  3. Sep 26, 2019 at 7:32 PM
    #63
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    I oriented mine the other way as well and because of that, I was able to undo my LCA's, push out my bushings, and use a whole small tub of Superlube @GHOST SHIP recommendation.
    The front end of my truck is now absolutely quiet.
    All that's left is finding out what size bushing my OME Dakar uses up front, press out the stock one, lube the shit out of the new one and put it all back together.
    GHOST SHIP likes this.
  4. Sep 26, 2019 at 7:43 PM
    #64
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    So you chased down the sound successfully? Nice! Dakar uses a standard size bushing. I’ve had a wheelers bushing in there but you can also get the yellow one from OME or red from Energy suspension. If you can hang on till we install your sliders, I have spare bushings in the shop.
    Kwikvette[QUOTED][OP] likes this.
  5. Sep 26, 2019 at 7:46 PM
    #65
    Kwikvette
    Fresno County
    4 run, 2 don't
    I can definitely wait.
    In the meantime, I'm rebuilding my manual hubs so I have a spare set as part of my 4x4 conversion.
    GHOST SHIP[QUOTED] likes this.
  6. Sep 26, 2019 at 11:55 PM
    #66
    eon_blue
    Azusa, CA
    When are you headed down here to do your sliders? If @GHOST SHIP doesn't mind maybe I can swing by and we can grab a beer in town, and maybe I can get started on my bumper wrap around too lol
  7. Sep 27, 2019 at 7:47 AM
    #67
    wheeliest
    Json
    TMPE AZ
    I Have Yellow Bushings in my Dakar leafs, Lubed once a year ago and still no sound. contemplated purchasing the Dobinsons Greasable Pin Kit but no reason if it aint squeakin
  8. Sep 27, 2019 at 8:01 AM
    #68
    Kwikvette
    Fresno County
    4 run, 2 don't
    Think he's starting them this weekend :welder:
    How far is the drive you think? 6 hours? Or is he closer to me than you are?
    So I actually prepped an extra set of LCA's; I pressed out the old bushings using the bottle jack method, and wire wheeled the shit out of the inner sleeve to get rid of the rust/paint.
    New sleeves slid in like nothing, so on installation day, I smothered the inner sleeve as well as the bushings themselves with all the grease Whiteline gives you.
    Maybe the grease they provide isn't all that great, or it is and I got a bad batch.
    Regardless, I pulled the bushings yesterday and used an entire small bottle of Superlube.
    Overheating would suck, but that whine though.
    Idk how Ryan doesn't have a hard on every time he hits the throttle on his truck :anonymous:
    I've got the yellow OME bushings in the rear of my Dakar's as well; the rears make minimal noise. Where the majority of the noise comes from is the front bushing that OME presses in. That's the one that'll get replaced.
  9. Sep 27, 2019 at 10:18 AM
    #69
    Kwikvette
    Fresno County
    4 run, 2 don't
    If that's a 2nd gen, then you're in the wrong section.
    :boink:
  10. Sep 27, 2019 at 10:21 AM
    #70
    wheeliest
    Json
    TMPE AZ
    oh crap haha whoops
