LCA Bushings: Polyurethane vs Rubber
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cortland, Dec 8, 2014.
  1. Dec 8, 2014 at 10:06 AM
    Cortland
    Cortland [OP] Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    What are the pros and cons of both?
    Energy Suspension sells polyurethane bushings for $90 shipped for both sides.
    Or I can get Moog rubber bushings for about $55.50 from RockAuto.
    Any suggestions?
  2. Dec 8, 2014 at 10:50 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    For stock arms? The harder poly bushings will last longer but transmit more road vibrations. I have delrin bushings (nylatron) from chaosfab in my LT arms, last forever.
  3. Dec 8, 2014 at 10:52 AM
    Cortland
    Cortland
    California
    Yes they would be for stock LCA's
  4. Dec 8, 2014 at 11:02 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    OEM rubber bushings are softer so more "mall friendly". Poly bushings are more ridged so give better stability to the part but transmit more road info....as in they ride a bit harsher (and squeak really bad if you don't lube them), but are a more "positive type of mount.
  5. Dec 10, 2014 at 11:33 AM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    my LCA bushings are shot, makes a ton of noise. Just debating if I should swap them out or wait out til sometime next year when I do the LT up front.
