LCA bushings....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by abqnurse80, Jan 12, 2019.
  1. Jan 12, 2019 at 6:15 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Does your truck pull any direction or go straight? Does it make any noise associated with the bushings? If it goes straight and doesn't make any noise, don't worry about it.
  2. Jan 12, 2019 at 10:34 PM
    abqnurse80
    abqnurse80 [OP] Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    More so truck wandering a bit. Know about the intermediate shaft, doesn't look loose to me. Tracks straight, noises, yeah, lots of them... going to strap a GoPro under there and hopefully see what's going on.
  3. Jan 12, 2019 at 10:34 PM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Straight, I think my lca bushings are next culprit on the list...
  4. Jan 13, 2019 at 3:59 AM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Check the rack and pinion bushings too, also a quick visual on the outer tie rod ends. You'll need to remove the front skid plate to get a good look at the R&P.
  5. Jan 13, 2019 at 4:45 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Outer tie rods looked good yesterday, have not looked at the rack... My luck probably needs those as well.. a chance to fix a stripped skid bolt as well.... The fun never ends!!!
  6. Jan 13, 2019 at 4:50 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    abqnurse80[OP] likes this.
  7. Jan 13, 2019 at 5:07 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
  8. Jan 13, 2019 at 12:52 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Before taking apart the LCA's, check that your hardware is not frozen with rust. With truck on level ground, each cam bolt should slide out (use a rubber mallet to tap out). The front facing bolts are the ones that usually freeze first. To me, that wear in your first post can be normal unless the crack goes all the way through. The harshness you describe is a symptom of deteriorating bushings. A sign of significant wear will be uneven tire wear and clicking noises when turning sharply and/or driving over sharp uneven terrain. Polyurethane bushings have their disadvantages; they tend to squeak in the long run and may exhibit a harsher drive than rubber mounts; they are also pricier. Take a look at Mevotech bushings. They use a rubber-polyurethane blend and are not pricey.
  9. Jan 13, 2019 at 2:05 PM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Yeah, will check on that before getting everything apart. The polys are sounding more like a headache and not worth my time. From the look of things, they just seem very hardened, and something is just not right. The movetech looks like a good option. Just have been chasing a zebra, but can't stand how the truck feels.... Hard to get a handle on what is going on, and I feel over my head. Problem being places I have taken it to have missed other major things. Had a near seized and rusted uniball on my uppers. Other numerous issues with places that have destroyed my trust in taking it anywhere, and have incurred signifficant cost to me... I'm at a loss at the moment...
  10. Jan 13, 2019 at 4:51 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    The bushings just take time and are worth every second of "trouble" if you plan on running your truck into the high mile world. The only challange is getting the old bushing out...after that the new poly or blend bushing going in is a much easier process which has to be done regradless what you replace the old bushing with. If you're not confortable, most shops should be willing to press them out and in for a small fee. Doing this work NOW will save you from being in the exact same position again sooner than later.
    Its easy to feel like things are over your head but really its not all bad, trust me. PM me if you like and I'll get you my phone number, maybe I can walk you through some of it.
  11. Jan 14, 2019 at 1:54 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Thanks man, Will send you a pm!!!
  12. Jan 14, 2019 at 11:57 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Same set I run in my truck, rebuilding a spare set of LCA's right now with another set of them as well. I originally used Pro-Forged LCA Ball joints which were supposed to be heavy duty, but their boots suck so I'm switching to the MOOG internal boot design. Press in as well, although the Pro-Forged boots were 100x harder than hell to press in...
    I took a recip-saw to my stock LCA hardware to get them out, everything was seized. Swapped in all OEM hardware lubed up with Prothane Supergrease. Adjusts mint still after 2 salty winters and over 40k miles.
  13. Jan 14, 2019 at 3:38 PM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Yeah I'm hoping things aren't seized, haven't had time to check, hopefully in the next couple days, but the more I look, things seem suspect. I think my truck lived by the beach quite a bit in la. Well, have parts on order, will update when I get things in and ready to go!!! Thanks a lot for the information guys!!!
  14. Jan 14, 2019 at 5:01 PM
    08TacoTrD
    08 TRD Offroad
    If the bolts and cams are seized and won't come off. These blades are ridiculous for cutting through them.
  15. Jan 14, 2019 at 5:06 PM
    #35
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Hopefully won't come to that!!! But will have a couple on hand... From my being at a loss yesterday, I'm determined to get my truck right. I can't trust any shop at this point. Only my fellow tacomaworld peeps!!! Thanks for all the info!!!
  16. Jan 17, 2019 at 1:03 PM
    #36
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Just to review some footage... is this much movement normal???? Just with turning the tires, and stopping back and forth???
    https://youtu.be/l5_tFj0b6K8
    Video might take a while to process, uploaded at 1403 MST. Thanks for any help!!!
    DrFunker likes this.
  17. Jan 17, 2019 at 1:26 PM
    #37
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
  18. Jan 17, 2019 at 7:29 PM
    #38
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Just checking on what u all think!!
  19. Jan 17, 2019 at 8:21 PM
    #39
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    I'm by no means an expert but it sure looks to me that they are a little loose. Interested in hearing what you figure out.
  20. Jan 17, 2019 at 8:32 PM
    #40
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Well, for a couple hundred, I'm replacing, the way my shocks ride, something is up, and the lca are the last thing to tear apart!!!! Thanks!!!
