LCA bushings....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by abqnurse80, Jan 12, 2019.
  1. Jan 17, 2019 at 8:40 PM
    #41
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Cut it! Cut! Cut it! Cut it! Cut it! Them prices are too high you need to cut it! Them cams are corroded you need to cut it!
    Seriously the carbide diablo will make surgery easy.
    abqnurse80[OP] likes this.
  2. Jan 17, 2019 at 8:40 PM
    #42
    Montanahunter
    Montanahunter Well-Known Member
    Zhaun
    Helena Montana
    2009 DC TRD off-road
    OME lift Stealth custom wheels ARB bullbar Allpro Apex sliders Prismo design roof rack.
    ^^^ this^^^ I've never watched a good one like that for comparison. I would expect that any flex that the bushing endures would bounce back to center. That definitely looks like it is sloppy.
  3. Jan 17, 2019 at 8:53 PM
    #43
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Op, if I had to guess...I am going to say your passenger side lca will probably be seized in the rear. I have done four different lca swaps from 60-100k miles. All seized on that side at a minimum, but hope you are lucky. There is a reason that all the nice lcas and long travel kits run poly bushings as they won’t corrode internally and seize.
    I say either live with your lcas or commit to doing the job right or you could be doing round three in a few years. There is a reason why aftermarket lcas arnt cheap. My buddy actually converts stock lcas with poly bushings and reinforced playing if you are interested. Good luck.
  4. Jan 17, 2019 at 9:46 PM
    #44
    abqnurse80
    abqnurse80 [OP] Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    For convienence sake, I'm going with the mecotechs to get up and running. Will rebuild originals with poly when time provides, grad school and such!!!! Have blades and cams in standby if needed!!!! Thanks and will update!!!
    Coot83[QUOTED] likes this.
  5. Feb 5, 2019 at 3:28 PM
    #45
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Well got the LCAs on a few days ago, and just got her all aligned today... Difference is night and day. Wandering is gone, harshness over bumps is gone, odd sounds that I wasnt even aware of, all gone... Steering wheel vibes, gone.... My god... should have done this one day one... Only one cam bolt was kind of suborn, had all sprayed days before hand. If your front end is in rough shape, check your LCAs!!!!!!! Im a happy camper with mevotech LCAs, will post updates as I put on the miles
    cmbondo and DrFunker like this.
  6. Feb 5, 2019 at 3:45 PM
    #46
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    Hell yeah! Glad you got it figured out.
  7. Feb 5, 2019 at 3:53 PM
    #47
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Was going crazy over the last few months... What really irks me though, I have been to at least 4 independent shops.... None of them caught my rusted out uca uniball, or the slop in my lcas.... Well, I have learned a lot am more self sufficient, and have got to known the suspension of out 2nd gens intimately...
  8. Feb 5, 2019 at 3:57 PM
    #48
    cmbondo
    San Diego CA
    DIY is the only way. Seems you can't trust anyone in a shop anymore.
  9. Feb 5, 2019 at 4:01 PM
    #49
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Although, I did find an awesome alignment place today, thanks to some local recommendations in the Southwest NM group here. Nice to have a caster of 3.5
    cmbondo[QUOTED] likes this.
  10. Mar 19, 2019 at 9:20 AM
    #50
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    sub-d
