LCA BUSHINGS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KBraden79, Aug 13, 2024.
  1. Aug 13, 2024 at 7:07 AM
    KBraden79
    KBraden79 [OP] Active Member
    2012 trd sport Tacoma
    Does anyone know if the moog LCA bushings are any good? Amazon has them for $15 a piece with 4.8 out of 5 stars. And are both bushings the same size?
  2. Aug 13, 2024 at 12:50 PM
    Sailor_Nick
    Sailor_Nick Well-Known Member
    Nick
    Massachusetts
    2011 Tacoma TRD-OR DCSB 6-speed
    Bilstein 5100's, 32" tires
    I replaced my LCA bushings with MOOG a few years ago and I would 100% NOT do it again.
    If you look at stock bushings, the rubber that connects the inner sleeve to the outer sleeve is positioned at 12 and 6 o'clock. making the bushing connected at 2 spots and able to have lots of flex and articulation about the pivot axis. Low NVH and smooth articulation
    MOOG bushings are essentially solid rubber all around from what I can tell and they ride MUCH harsher than stock did. MUCH more rubber resisting the motion of the arm in compression and extension.
    I'm actually buying OEM arms and bushings very soon to replace mine because I'm very unhappy with the ride of the MOOGs.
    KBraden79[OP] likes this.
  3. Aug 13, 2024 at 12:55 PM
    KBraden79
    Thank you! I’m not 100% sure I need them but if I did I’d like to buy just bushing because my ball joint looks fine. I have TRQ lower control assembly right now.
