LCA BUSHINGS
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bigd83, May 5, 2025.
  1. May 5, 2025 at 4:41 PM
    Bigd83
    Bigd83 [OP] Well-Known Member
    2000 sr5
    Can anyone tell me the difference between the forward and rearward lca bushings? I'm looking at both brand new and they look identical.
  2. May 5, 2025 at 4:42 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    They are
  3. May 5, 2025 at 4:44 PM
    Bigd83
    2000 sr5
    Then why different part numbers? And a few cents difference in the price.
  4. May 5, 2025 at 4:45 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Don't know, I've only ever bought aftermarket and polyurethane kits which are not labeled because they're identical
    Maybe different on a 5 lug model? Not sure what you have
  5. May 5, 2025 at 4:46 PM
    Bigd83
    2000 sr5
    I swear ordering OEM parts,.,... they're friggin retarded!
  6. May 5, 2025 at 4:47 PM
    Bigd83
    2000 sr5
    6 lug 4wd.
  7. May 5, 2025 at 4:48 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Eh, give it 15 mins for TW to say I'm wrong and there's a 2.1 degree difference on the taper before ordering, idk
    drizzoh, Wulf, TACOTU3 and 1 other person like this.
  8. May 5, 2025 at 4:50 PM
    Bigd83
    2000 sr5
    80 bucks apiece! I've been stripped of my non existing wealth!
  9. May 5, 2025 at 5:23 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Do yourself a HUGE favor. Replace the complete LCA with new bushings. Getting those bushings out is a bitch and no guarantee the new ones will fit snuggly.
  10. May 5, 2025 at 5:35 PM
    Bigd83
    2000 sr5
    I've already ordered everything under the front end. Including rack. Excluding coilovers, (those are next). I've got a good shop lined up to install everything for me. I bought new cams and bolts in case they have to be cut. Nothing looks bad at all underneath. No rust whatsoever. But I'm too old to crawl around under these trucks so had to hire someone.
  11. May 5, 2025 at 5:37 PM
    Bigd83
    2000 sr5
    I do kinda wish I had just bought the lca assemblies. But this is my first go around and it's been a learning experience.
    CD20H[QUOTED] likes this.
  12. May 5, 2025 at 7:15 PM
    CD20H
    Ben
    North Texas
    I learned the hard way also. Spent 6 hrs getting the bushing out. I ended up cutting out the outer sleeve the bushing with a hacksaw.
  13. May 5, 2025 at 7:43 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Brother, I understand you on that situation 100%. When it comes time for my front end rebuild, I'm going to try and find me a local TW member or two and throw myself on their mercy for help. Of course I'll buy them food, and beer, and other beverages as needed. There is no way I can do this anymore without serious help.
    Bigd83[QUOTED][OP] likes this.
  14. May 6, 2025 at 2:01 AM
    Bigd83
    2000 sr5
    Old bones!
  15. May 6, 2025 at 6:04 AM
    02hilux
    Planet: EARTH
    As long as the truck is not from the rust belt, there should be any issue. I’d done well over a dozen and most are trouble free while one or two require heat to get it going. As for the install, snugged fit. But like I said, location makes a difference.
    treyus30 and Bigd83[OP] like this.
  16. May 6, 2025 at 6:11 AM
    Bigd83
    2000 sr5
    My truck was bought originally in California. then went to Az. Then Tn and now Ms. Guess I'm lucky has no rust at all. But thinking I should maybe start soaking nuts n bolts with penetrating oil before it goes to the shop next week? Would probably make their job easier. And faster! Just in case, I ordered new cams n bolts though.
  17. May 6, 2025 at 6:17 AM
    02hilux
    Planet: EARTH
    You can but if there’s no rust, it’s not necessary. If you got penetrating oil, great. If not, ATF or ATF & acetone mixture works well too. Pour it into a spray bottle and spray it around everything that will be remove.
  18. May 6, 2025 at 6:27 AM
    Bigd83
    2000 sr5
    Never tried that mixture. I've got half a dozen cans of tech grade knock er loose. It's always done good for me. I'll have to try that trans fluid w acetone sometime tho. Thinking about it, sounds like it would be a good mixture. Thanks Hilux!
    02hilux[QUOTED] likes this.
  19. May 6, 2025 at 6:36 AM
    02hilux
    Planet: EARTH
    ATF provides the lubricant while the acetone penetrate rust. Both are commonly found if you’re a DIY mechanic. I don’t bother buying penetrating oil.
  20. May 6, 2025 at 6:41 AM
    Bigd83
    2000 sr5
    Yea I have access to acetone and plenty of other solvents here at work. We blast n paint structural columns and beams. I'm mostly maintenance. Rebuild about anything that breaks.
