LCA cam bolts - Are these a wear item?
Discussion in 'Suspension' started by wi_taco, May 25, 2022.
  1. May 25, 2022 at 8:31 PM
    wi_taco
    wi_taco [OP] My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    First and foremost this is going to be an insanely stupid question so please humor me...
    Just found my front passenger LCA eccentric is frozen. The other three are moving, no rust, and fully lubed with anti-seize. That means at minimum I need to replace my passenger LCA and the front eccentric bolt that need to get cut out.
    The dumb question: Are these 4 cam bolt assemblies a wear item? If my main concern is doing the job right should I replace all 4 eccentrics at the same time or is that just crazy talk? I've searched as much as I can and it doesn't seem like anyone in their right mind would replace them unless they are frozen.
    Thanks in advance!
  2. May 25, 2022 at 8:34 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Not generally considered a "wear" item or single use only.
    They are denoted as reusable according to the FSM, although that is dependent upon condition; if you find that they are pitted grooved or otherwise worn excessively to your comfort level then of course go ahead and replace them, but no, they are intended to be reused until they are no longer serviceable.
    wi_taco[OP] likes this.
  3. May 25, 2022 at 8:36 PM
    wi_taco
    Adam
    SE Wisconsin
    Perfect thanks. I must have missed that note in the FSM, greatly appreciate the confirmation! Should save me about $100 not having to buy duplicate parts.
  4. May 25, 2022 at 8:38 PM
    Key-Rei
    Key
    Florida
    More precisely I should say it's not noted as single use like exhaust gaskets etc (which even so I also still reuse until they start leaking) therefore it's reusable.
    wi_taco[QUOTED][OP] likes this.
  5. May 25, 2022 at 8:45 PM
    wi_taco
    Adam
    SE Wisconsin
    Ahh I see what you mean about it not being noted. I did notice that but figure it doesn't hurt to ask because no manual has all the real-world answers. Still good to hear that I was on the right track thinking not all 4 have to be replaced if not needed. Again thanks!
    Key-Rei[QUOTED] likes this.
