LCA cam seizing repair
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RecklessTLS, Aug 22, 2022.
  1. Aug 23, 2022 at 6:25 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    If your cutting the cam bolts, the bushings need replaced.
    You’re this far into it….
    Save yourself the headache of trying to get the cut bolts out of them and just replaced the bushings.
  2. Aug 23, 2022 at 8:04 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You guys talking about putting the antiseize on the threads?
  3. Aug 24, 2022 at 4:24 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    To be clear, I did not apply anything to the threads as that's not the failure (corrosion) point. No problems with mine coming loose and we're a year annd a half down the road.
    As for Fluid Film "not allowing the bolt(s) to come loose on their own", it too is a lubricant, so I don't understand the logic.
    reallifedog, SR-71A and Torspd like this.
  4. Aug 24, 2022 at 6:49 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Dont anti seize (or grease) the face of the cams. I dont think a little on the threads will hurt anything in the rust belt, but as @Too Stroked said you only need to coat the parts that actually stick, which is the bolt and sleeve
  5. Aug 24, 2022 at 7:00 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    I used SPC can bolts on my 4runner. They will never seize because they have a plastic sleeve.
    Torspd likes this.
  6. Aug 24, 2022 at 9:05 AM
    saint277
    saint277 Vigilo Confido
    It has no were near the lubricating properties of an antiseize or grease, thats the logic, its pretty simple.
  7. Aug 24, 2022 at 4:30 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yeah, I tried to keep it off the threads, just lubed inside the bushing sleeves and the unthreaded portion of the bolts. That is the interface that corrodes itself together. BUT, it's kind of hard to pinpoint apply any of these products.
    SR-71A likes this.
