LCA hitting ball joint
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scoobarooo, Jan 23, 2017.
  1. Jan 23, 2017 at 9:10 PM
    #41
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    So it has 4 stops for compression?
    Well I thought I was helping but sounds like I may have led astray.
  2. Jan 23, 2017 at 11:03 PM
    #42
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Yeah, it has a front and back bumpstop for each wheel. The top-out is (I believe) the shock. OP has an 02, which should be the same, but not 100% sure.
  3. Jan 23, 2017 at 11:18 PM
    #43
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    O2 is the same
    jbrandt[QUOTED] likes this.
  4. Jan 24, 2017 at 1:29 AM
    #44
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yip only bottom bumps for our trucks. Also now that i look at that pic closer its somewhat obvious it's not a tacoma. I didnt notice that at first though.
  5. Jan 24, 2017 at 5:47 AM
    #45
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Alright then, well I'll double check, but when it was on the lift I had no problem with the spring at full droop
  6. Jan 24, 2017 at 5:55 PM
    #46
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    couple things. mainly, jbrandt has a really good point my alignment tech buddy mentioned to me which could be 1 fix for the situation. youll probably need new LCA bushings or a new arm. when you do get new ones, the alignment tech will basically reset the lower arms at a new clock position on the initial alignment. this will fix that issue.
    as far as figuring out what you can do to fix the top bumper issue, you MIGHT be able to find an extended spindle for the lift you have. this will tilt the upper control arm back up to original height and prevent premature bumping and/or prevent any spring plucking.
    doing one or both of these *fixes* should completely fix your situation. there is also the option of finding a crossmember that will drop the position of the lower control arms on the chassis down a few inches and give you more clearance. but at that point youre buying a whole new lift kit.
    just some things to think about.
  7. Jan 24, 2017 at 5:56 PM
    #47
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Currently looking into UCA's, which I believe should fix the plucking
  8. Jan 24, 2017 at 5:57 PM
    #48
    CodeSeven
    Serge.
    Coachella Valley
    i edited that post and added more info. check it out.
  9. Jan 24, 2017 at 6:03 PM
    #49
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    I don't really like the look of those lower crossmembers. Doing the lift for the clearance and that kind of kills it.
  10. Jan 24, 2017 at 6:08 PM
    #50
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Limit straps should help with your issue.
  11. Jan 24, 2017 at 8:06 PM
    #51
    bry838
    oregon
    The top bump stops under the UCA dont exist on our trucks.
  12. Jan 24, 2017 at 8:35 PM
    #52
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    late to the party but yeah, no upper interference for the Tacoma, only lower bumpstops on the LCA to prevent suspension travel up into the wheel well.
    with the "lift" you've eliminated the lower bumpstops from the equation and now rely on your shock to bottom out if you compress too much
    double check your sway bar as with the amount of lift you added you "rocked" the sway bar most of the way forward and could be contacting under the crossmember or you're hearing the sway bar bushings stressing as one wheel tries to go beyond the now more limited travel distance. That's one of the reasons a lot of people remove the sway bar, but also to increase individual wheel travel (articulation).
  13. Jan 25, 2017 at 3:00 PM
    #53
    jbrandt
    Justin
    I could be mistaken, but I don't think this is true.
    With a spacer lift, yes, you could be relying on the shock to limit your compression travel because you moved the entire shock down, so if the wheel moves up enough that the shock is fully compressed before it hit the bump stops, you're in trouble.
    But that's not the case with 5100's. All you're doing is extending the shock body when you apply the lift. Since the main shock body is still in the same place, (i.e. not moved down by a spacer), the wheel can still travel that far UP. As far as down travel, that is always limited by the shock, so I wouldn't be worried about that.
  14. Jan 25, 2017 at 3:51 PM
    #54
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    It's not from compressing. It's from extending. Funny enough, when someone is in my truck with me, this noise disappears. Like the weight helps?
  15. Jan 25, 2017 at 6:25 PM
    #55
    CodeSeven
    Serge.
    Coachella Valley
    could just be the sway bar knocking up and down on the links. a passenger would keep them more even with each other
  16. Jan 25, 2017 at 6:31 PM
    #56
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    I disconnected the sway bar links to confirm. Noise is still there.
  17. Jan 25, 2017 at 6:34 PM
    #57
    CodeSeven
    Serge.
    Coachella Valley
    only other thing i can think of is a bad ball joint that knocks to and fro when moving vertically.
  18. Jan 25, 2017 at 6:36 PM
    #58
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    It's possible. I'd hope not though. Toyota did the recall 35k miles ago.
