LCA moves on its mounts?!!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jlvhrse, Dec 18, 2011.
  1. Dec 18, 2011 at 4:22 PM
    jlvhrse
    jlvhrse [OP] Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    After working retrieval at the Rage at The River Race in Laughlin NV I developed a new clunk. It happens whenever I go over bumps on a bad street (or offroading). It sounds like a metal on metal clunk coming from my front suspension. My 4x4 high and low both still work fine, it does not seem to affect my steering, accelerating or breaking. The only thing I have noticed is a small shake on my front end when driving which is much more noticeable when going downhill, even at 30mph.
    There is no noticeable damage to the suspension other than the fact that my LCA moves on its back mount (closest to the cab) when I move my tries (in park). I also get a similar clunking noise when turning my tires which is only noticeable when in park. Here is the video.
    I am hoping this is only a bad bushing and that it will solve my clunk noise.
    I also get a clicking / clunking sound when breaking to a stop, most noticeable going from about 10mph to 5mph. It seems to be coming from under the truck toward the back, possibly where the drive shaft connects to the rear pumpkin? It sounds very similar to the noise I got when my drive shaft was "popping up and down" in the u joints right before my drive shaft fell off at about 30,000 miles (replaced under warranty). I have greased my u joints since this noise started and it did not help. Any ideas on this one?
    Sorry for the long post.. Thanks in advance for all your help and suggestions!
  2. Dec 18, 2011 at 4:24 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    cant see the video but it sounds like you need new bushings lca shouldnt move like that
  3. Dec 18, 2011 at 4:29 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Not sure what the clicking is
  4. Dec 18, 2011 at 4:30 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    time to go LT...j/k
    some play in the bushings is fine..they are made of rubber after all.. i think your bushings appear to be pretty worn out. is that where the noise is coming from?
    hows the appearance of the bushing..are they cracked, torn, or ripped? is there anything obvious that might indicated they are shot besides from looking at the excessive play from the what the video shows?
  5. Dec 18, 2011 at 4:34 PM
    MonkeyProof
    SoCal- SGV
    silly question and i think you already mentioned that SDHQ's pit crew guys looked everything over..but have you had your b/f check the bolts to the upper and lower control arms recently?
  6. Dec 18, 2011 at 4:41 PM
    jlvhrse
    Jen
    SoCal SGV
    Thats what Aaron and I are thinking..
    Yeah it moves a lot
    The noise when I turn my wheels is coming from the LCA for sure but I am not 100% sure that is the same noise that happens when driving over bumps and is not the same noise that happens when decelerating for sure. SDHQ tighetend almost every suspension bolt for me but it did not fix any of the noises. We can not see the bushings with out taking it apart which we have not done yet. But I will post pics when we do for sure.
  7. Dec 18, 2011 at 4:45 PM
    MonkeyProof
    SoCal- SGV
    i think the first step obviously is to replace the bushings since there isn't much involved. and go from there to figure out the other noises
  8. Dec 18, 2011 at 6:34 PM
    jlvhrse
    Jen
    SoCal SGV
    i agree, i was just trying to see if anyone thought of anything that aaron and I did not..
  9. Dec 18, 2011 at 6:50 PM
    09taco4x4
    09taco4x4 Well-Known Member
    Louisiana
    09 DCLB TRD Sport 4x4
    Valant cold air intake kit Borla catback exhaust 6" Pro Comp Stage 1 Walker Evans 2.5's w/ TSB spring and add-a-leaf Light racing upper a-arms 285/70/R17 Dynapro ATM tires 17x9 XD wheels
    Same problem I had after I got my truck aligned. The alignment tech didnt tourqe the LCA bolts correctly and it took me a long to figure it out.
    Check to make sure the LCA bolts are tourqed
    tourqe spec is 150 ft. lbs.
  10. Dec 18, 2011 at 8:04 PM
    jlvhrse
    Jen
    SoCal SGV
    thanks!! :D
  11. Dec 18, 2011 at 8:09 PM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    I also had at pop/clunk noise from the front. Same thing as 09Taco4x4, Damn LCA bolts were not correctly torqued after an alignment.
  12. Dec 18, 2011 at 11:21 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    I've had a noise like that coming from my drivers side front suspension area for the longest time...this just may be it. I originally thought it may be my uni-balls on my Icon UCA's, but I had those changed and I still hear this clunking noise when I hit bumps. I'm pretty sure its coming from the LCA on the drivers side. Sounds like the video to....is this something that would be under warranty???
  13. Dec 18, 2011 at 11:24 PM
    Canadianboy
    James
    Vancouver, BC
    How do you address this? Do I just take my torque wrench to the bolt/nut that was in the video there? Would that change my alignment specs at all???
  14. Dec 19, 2011 at 11:39 AM
    jlvhrse
    Jen
    SoCal SGV
    I am under extended warranty and unless I take my whole suspension off and put stock parts back on I know they wont cover it. They might also say that a bushing is an item that will wear down just like tires or breaks.. who knows. If it is just a loose bolt and a bad bushing it will be a cheap fix (assuming you dont have to pay someone to take the suspension apart). Try having someone turn your wheels for you when you are in park and check to see if your LCAs are doing the same thing. I have not had the time to fix it this weekend, we will do it next sunday. I will post to let everyone know the results. Hopefully it will fix my clunking noise!! :pray:
    Good question... anyone have an answer? Not that my alignment matters right now as its so off I need one anyways.
    Thank you! I will post after we work on it to let everyone know how it turns out!
  15. Dec 19, 2011 at 11:45 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Ugh. Dry steering! :goingcrazy:
  16. Dec 19, 2011 at 11:51 AM
    06RadiantRed
    CA-Bay Area
    I just torqued it down good and tight, and it went away. I am unsure if my bushing are shot though.. i feel like even with bolts being loose, there should not be as much play as i had. But torqued down, it all seems to be ok so far. that was about 4k miles ago? cant remember exactly but its been a while and remains noise free.
  17. Dec 19, 2011 at 12:09 PM
    jlvhrse
    Jen
    SoCal SGV
    lol :anonymous:
    nice!!!! I will try the same as soon as I can!
  18. Dec 19, 2011 at 12:10 PM
    pancho
    pancho Go home Nubbs, street lights are off!
    Pancho
    Southern California
    18 Cement OR 4x4 DCSB
    Black out emblems. TRD Pro grille.
    Check the printer cables. I'm pretty sure that's what it is ^_^
  19. Dec 19, 2011 at 12:12 PM
    jlvhrse
    Jen
    SoCal SGV
  20. Dec 19, 2011 at 12:16 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    From what it looks like moving that bolt will change alignment (hard to see from the video and I have a 1st gen). The bolt on the backside does not though. One of the bolts is connected to the flat aglignment cam tab, do not move that one. The other side should be a bolt with a washer, that one you can tighten without changing alignment
