LCA Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pugga, Apr 28, 2012.
LCA options...
Poll closed May 28, 2012.
  1. Let Toyota have at it and pray
    5 vote(s)
    14.3%
  2. Replace LCA bushings myself
    18 vote(s)
    51.4%
  3. Deal with the crappy ride
    0 vote(s)
    0.0%
  4. Something else
    3 vote(s)
    8.6%
  5. Potato (Click here if you're a tool and have nothing constructive to offer)
    9 vote(s)
    25.7%
  1. Apr 30, 2012 at 5:31 PM
    #41
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Dam that sucka is on there .
    If you need a tool that you don't have let me know I might have it or I might have it at work. Good luck mike !
  2. Apr 30, 2012 at 5:47 PM
    #42
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Thanks John! I'm going to keep working it and see if I can get them to break loose, if not I'll be replacing the bushings.
    Thanks again and likewise, if you need any tools, let me know, I do have some random crap laying around!
  3. Apr 30, 2012 at 6:53 PM
    #43
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Yeah, its a bit more challanging than I had imagined. I had a mental picture of a simple cam head bolt, without the second sleeve. I personnally wouldn't be giving up yet, but I'm as stubborn as they come.
  4. Apr 30, 2012 at 7:00 PM
    #44
    Pugga
    Massachusetts
    This is the bolt that's giving me problems, no second sleeve. Those are on the fronts which broke free thankfully. I'm not even close to giving up, I'll try it daily (or as close to daily as the weather allows) for a week or 2. If it really won't break free, then I'll bite the bullet, rent a press and put in some new bushings. I'm pretty stubborn myself and can't afford to have the truck down :D
    Also, I did affect the alignment when I broke everything free. It's not bad yet but I can definitely feel that it handles differently in a tight corner.
  5. May 1, 2012 at 12:42 PM
    #45
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It went away when I replaced the upper control arms. So it might have been the factory upper ball joint. But I also think it might have been that I never loosened the upper control arm mounting bolt - so it was holding the factory upper control arm bushings at the "stock" ride height angle.
  6. May 2, 2012 at 5:22 PM
    #46
    Pugga
    Massachusetts
    Update, 3 out of 4 are seized, not just 1. +1 to Boyd for putting up those pictures, made me realize that just because the front bolts will spin, the sleeves can still be rusted inside the bushing.
    End result, I'm replacing all 4 bushings, going to cut them out like Boyd's write-up, try to press them out, if not I'm cutting the MFers. Everything's ordered up through Camelback Toyota, taking advantage of their 5% off sale (FYI, their list prices are still 30 - 40% cheaper than my local stealership). Going to start on it next Friday and I need the truck up and running for Monday. Should be a fun weekend :D
  7. May 2, 2012 at 5:56 PM
    #47
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    woot good luck
  8. May 2, 2012 at 7:30 PM
    #48
    seric007
    seric007 Well-Known Member
    let toyota have at it. if its f***ed then just take the truck back and tell them to blow.
    they cannot MAKE you purchase anything.
    replace the bushings and get a proper alignment from a shop that knows their ass from a hole in the ground.
  9. May 2, 2012 at 7:40 PM
    #49
    jandrews
    '09 FourDubDee TRD OR
    Stuff like this makes me glad that:
    - I live in the south where all our shit doesn't seize after one month of winter.
    - My truck needs an alignment like every 1-2 months, so my cams are constantly being spun. Should keep 'em loose.
  10. May 3, 2012 at 5:05 AM
    #50
    Pugga
    Massachusetts
    I think you missed the first post... they wouldn't touch my truck unless I consented to paying for anything they break in the process. If I let Toyota have at it, I'd potentially be on the hook for a very expensive repair. Plus, if I do it, I know it'll be done correctly and all the parts actually lubed up before install so I won't have this problem in another 70k miles. As far as the alignment, this is the first tech around here that actually knew what I was trying to accomplish. I've been to 2 other dealerships and 2 other tire shops and they haven't gotten it right yet. We don't have a whole lot of off road shops around here.
    I hear ya about the salt... although, if Toyota actually put some sort of grease from the factory, I wouldn't have this problem! Sadly, I've had my truck aligned several times and apparently all they did was adjust the toe and call it good. There's no way the cams have ever been spun.
  11. May 3, 2012 at 5:08 AM
    #51
    brutalguyracing
    F.U> GUYZ
    broken mods
    they could have spun the cams....they tend to seize up rather quickly....
    i have had like 25 alingments since i owned the truck...and i had both lca replaced by toyo under warranty.......
    and when they put the new arms iin they left the stickers on the bolts and still did not use any grease or anti sieze.....
    i guess thats job security........
  12. May 3, 2012 at 5:18 AM
    #52
    Pugga
    Massachusetts
    Those types of stories are disappointing... In the northeast, you need to gob that crap on! I can promise you the alignment tech isn't going to like me because there will be neverseize everywhere by the time I'm done :cool:
  13. May 3, 2012 at 8:53 AM
    #53
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Good luck pressing. I tried for almost a week with no movement and I was using a press with an impact on the end of it.
    You will still need a press to get the new ones in so you might as well try, but my guess is youll be cutting them out like I did.
  14. May 3, 2012 at 9:04 AM
    #54
    Pugga
    Massachusetts
    Kinda what I'm assuming. I'm going to rent the Autozone press for the reinstall so I figured I'll try to press them out. Sometimes it's better to be lucky than good!
    I'm doing this whole job without the assistance of an impact, just good old fashioned elbow grease, breaker bars and ratchets (I have a sawzall though, I'm not cutting the LCA bolts by hand!)
    Thanks for making the writeup, if there wasn't one I would have probably ended up ponying up for new LCAs :thumbsup:
  15. May 3, 2012 at 9:19 AM
    #55
    XXXX
    sKiP
    05 Prius
    I went through (4) Lenox laser cut metal blades on my sawzall and didn't get 1/2 way through the first bolt. I waxed each of them, ran them slow, and re-waxed when they got hot. Still burnt through them.
    IMO a grinder with a cut off wheel is soooooooooo much faster. When your almost through all the bolts change to a used cut off wheel that's real small so you don't end up nipping the frame or LCA mounts.
    When you get the LCA off....squeeze the LCA mounts towards each other for a good scare. They bend under hand pressure :(
    Also check your LCA bushing tubes real good before you rebuild them. I have seen a few failures where the tube rips from the back.
    Oh and if you need to cut the bushings out like I did make sure and cut where the tube is spliced so you don't accidentally cut into any vital parts.
    Ill PM you the link to all the pics I have of my re-build...not just the few I posted in here
  16. May 3, 2012 at 9:37 AM
    #56
    Pugga
    Massachusetts
    Great info there, thanks again for the help! I've got a grinder so I'll pick up some cut off blades for that as well as the sawzall. I did notice the LCA tabs have a fair amount of flex to them, hard to believe they can hande the pressure on that joint!
  17. May 3, 2012 at 3:13 PM
    #57
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    OK, you guys have me convinced to pull the suspension and grease it before it gets intense. Hopefully the 2 1/2 years I have owned the truck here in South Florida will have been more kind on it.
    As for using anti-seize, why? Overall it's not a very good water barrier, and is often better on high temp or high pressure applications. I was toying with the idea of something like Bel-Ray waterproof grease or similar.
    I did pull up a parts diagram, as far as upper ball joints they do make you buy the entire upper control arm. The lower arm diagram points out the ball joint as an item but does not list a part number. Seems the oem choices for ball joints alone don't exist, and even things like the aftermarket ball joint UCA's if they use an oem ball joint are a waste of money.
    Enlightening topic, thanks.
    PK
  18. May 3, 2012 at 3:43 PM
    #58
    Pugga
    Massachusetts
    You can purchase bushings for the upper control arms. I was able to find them here:
    http://parts.camelbacktoyota.com/pa...YOTA&model=TACOMA&submodel=&vehicleid=1434686
    They're $30/ea. I'm not sure if you can buy just OEM ball joints for the LCA but misc (aka XXXX) made a write up to replace the LCA ball joint also.
    You can use grease but I don't see never seize being a bad option for this either. I've used neverseize several time on bolts that will not be in a high temp or high pressure situations, it's just there to prevent the 2 metals from bonding to each other over time. I might end up using grease myself, we'll see.
    Lastly, nothing on the UCA's or LCA's are servicable so I'm not sure what you're going to tear down and grease. The only thing you might be able to do is pull the LCA bolts, grease them and reinstall them (which means you'd need an alignment). Your call but there aren't any grease zerks on the suspension components (really wish there were at this point).
  19. May 3, 2012 at 4:24 PM
    #59
    brutalguyracing
    F.U> GUYZ
    broken mods
    you can use a combo or anti sieze and grease
    make a nice lil slurry
  20. May 3, 2012 at 8:08 PM
    #60
    PMK
    Florida
    10 DCLB TRD Sport
    Upper arms do not show the ball joint separate. They do show bushings as a separate item though.
    I was considering getting Camburg Ball Joint upper arms, but since you need oem ball joints, and their website says the MOOG aftermarkets won't fit, seems like a better option must exist.
    As for the lower arms, yes, I was only considering preventative maintenance of pulling the bolts and cams, then greasing them upon re-installation.
    Other than the front suspension pivots getting greased to corrosion proof it, and a full brake system flush, I have finally gotten rid of all the oem fluids in the truck. Zerex anti-freeze and Mobil 1 in the engine, ATF, power steering, front wheel bearings, and rear end. Eventually I'll get aftermarket greasable U-joints.
    I'll mark the cams, accomplish the work. Then decide if it needs aligning or not. Hopefully the marks will realign, if not, at least those bolts will move letting them align it easily.
    Come to think of it, I have some tubes of expired anti-corrosion paste we use on aircraft called Mastinox. Bad for us but good for the truck. Might be better than grease.
    PK
