LCA Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ubaderb, Mar 8, 2021.
  1. Mar 8, 2021 at 2:18 PM
    Ubaderb
    Ubaderb [OP] Well-Known Member
    15 Tacoma TRD OR
    Anybody come across an aftermarket replacement LCA that isn't $1600-$2000? I looked under my truck today and noticed my lower ball joints were looking a little rough. There are plenty of stock replacements but I was wondering if there was an aftermarket option below the Dirt King and Total Chaos option. I guess I'm looking for an upgrade over stock but beneath a full blown Total Chaos arm.
  2. Mar 8, 2021 at 2:20 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    Unless you're going long travel, the general consensus is that OEM is your best option for performance and longevity.
    at least that's what they tell me on this forum lol.
  3. Mar 8, 2021 at 2:22 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I only know of three companies that make better than oem lca's, and all are intended for lt setups. The two you mentioned already and jdfab. Any reason oem isn't good enough? They should last well over 100k.
  4. Mar 8, 2021 at 2:24 PM
    Ubaderb
    15 Tacoma TRD OR
    That's pretty much what I have found as well, was hoping there was a magical set I haven't come across yet.
  5. Mar 8, 2021 at 2:25 PM
    Ubaderb
    15 Tacoma TRD OR
    No reason in particular honestly, I just wanted to see if I there was a mid grade option out there. There is a VERY good chance I just go all LT with JD's stuff. I can't stop drooling over it.
    ryfox0276[QUOTED] and whatstcp like this.
  6. Mar 8, 2021 at 2:27 PM
    ryfox0276
    Montana
    2013 RC 4x4
    Same man :drool:. Someday maybe
    whatstcp likes this.
  7. Mar 8, 2021 at 2:41 PM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    I replaced my rusty LCA's & blown bushings with Moogs, and also replaced all the alignment bolts with OEM hardware last May. I was going to do the Whiteline bushings, but ran out of time. Moog LCA's are good for me so far.
    https://www.amazon.com/MOOG-RK62129...arm+tacoma&qid=1615242952&s=automotive&sr=1-3
    Edit: oops I see you want an upgrade to OEM, which this isn't. My bad. I'll just leave it for peeps who might be interested.
  8. Mar 8, 2021 at 2:45 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
  9. Mar 8, 2021 at 2:48 PM
    Pilotjoe123
    Pilotjoe123 Well-Known Member
    Joe
    Eastern, NC
    2012 Pyrite Mica Tacoma Sport
    Trd Supercharger URD 2.8 pulley AFE momentum GT Cam gears DT shorties DT mid pipe Vibrant res Borla Pro XS HPtuners custom dyno Aem 340lph fuel pump agm x2 power 34 battery dynomat sso slimline Icon 2.5 coilovers Icon 2.0 rear RR All Pro 3” expedition leafs flip kit superbumps SPC ucas Whitelines 4.88 nitro gears Detroit Truetrac front/rear Mayhem Prodigy 35/12.50/17 Mickey Thompson Baja Boss M/T
    How many miles have you put through your moot Lca?
  10. Mar 8, 2021 at 2:59 PM
    LC7
    Far Nor Cal
    I have +10k miles on my Moog LCA's. I don't want to sidetrack OP's thread anymore, so i'm out after this post. He's looking for LCA's that are better than stock but less cost than the big boys.
  11. Mar 8, 2021 at 3:38 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    I went straight to OEM and didn’t pass go.
    $265 delivered from various online retailers was a no brainer for me. Same for OEM hardware.
  12. Mar 8, 2021 at 3:45 PM
    Goosie0080
    Goosie0080 Well-Known Member
    North East
    07 Tacoma Access Cab 4x4 base
    I replaced mine with moogs and im totally regretting it.. mine rub at full lock. and i have clicking noise that i suspect is coming from one of them...
    How are you guys liking yours?
  13. Mar 8, 2021 at 10:50 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I got Dorman LCA's and by 5K the ball joints had excessive play. I replaced them with MAS XL ball joints. I don't remember where I got them but they sure looked better than the POS Dorman's. The bushings are holding up well so far, but if you get Moog or Dorman LCA's, replace the BJ's - Mevotech or Proforged. I have about 15K on the Dorman LCA's.
  14. Mar 10, 2021 at 3:02 PM
    Turdyota3000
    Turdyota3000 Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    That clicking may be due to them having the wrong torque specs.
    I went with oem.
