LCA replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bob76, Jan 2, 2024.
  1. Jan 2, 2024 at 1:30 PM
    Bob76
    Bob76 [OP] Well-Known Member
    Bob
    2018 Tacoma Off Road
    The dealership says my front driver side noise when the wheel is near lock and the suspension is under high compression is the LCA bushing and they are not replaceable. Looking at options, I can go with the Toyota part for $458 each (I will do both sides, I figure if one is going the other is likely not far behind), or Moog, Mevotech, or Dorman replacement, all for under $200 each. While I absolutely don't want to compromise safety when it comes to brakes, tires, or suspension, I also understand that many OEMs sell their components under different names, and that other manufacturers make parts that are just as good or sometimes better than OEM for the same money. The fact that I've got 85K on a 2018 Tacoma and am replacing suspension parts already makes me think that I have nothing to lose by going non-OEM. My question is this: Out of these companies (including OEM), are there any that are significantly better or worse than the others? Thoughts? I do tow, have a steel front bumper, winch, and will be putting on an OME lift when I do the LCAs if any of that matters.
  2. Jan 2, 2024 at 1:35 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
  3. Jan 2, 2024 at 1:47 PM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    You can get replacement lower balljoints from Ebay from Japan (for whatever reason Toyota USA doesn't sell them here) for about $100/pair. Part 43330-09510
    You can use the Whiteline bushings above to rebuild the inner bushings.
    I have a set of both of these above sitting in a freshly painted set of used LCA's I found. I have a bunch of other stuff to do at the same time (more bushing work throughout the front end) so it will be a few months before I have them in.
    Taco47 and Ricardo13x like this.
  4. Jan 2, 2024 at 2:04 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The Toyota LCA is like $265 online. Your dealer's retail markup is high
    https://parts.lakelandtoyota.com/p/...--Rear--Upper--Lower/14762436/4806904060.html
    Moog is acceptable too but probably doesn't last as long.
    Bushing replacement requires a lot of butchery with a torch, shop press, etc.
    usmc2msu and Chew like this.
  5. Jan 2, 2024 at 2:05 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I have those whiteline bushings installed in my truck. They've been great so far...
    A little heat and a bottle jack and the old bushings pop right out.
    Ricardo13x likes this.
  6. Jan 2, 2024 at 2:07 PM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    Toyota won’t press in bushings, so maybe take it to an independent shop and have some white line bushings installed.
  7. Jan 2, 2024 at 2:10 PM
    Ricardo13x
    Upland, CA.
  8. Jan 2, 2024 at 2:14 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^This works half the time. Other times the LCA deforms from jack pressure before the bushing budges.
    Ricardo13x[QUOTED] likes this.
  9. Jan 2, 2024 at 2:18 PM
    Ricardo13x
    Upland, CA.
    You only perform this with non rusted, soaked on pb blaster and using heat LCA’s. The link for the Whiteline bushings are for the 3rd gen. I have installed multiple sets on 3rd gen Tacomas and 5th gen 4Runners.
    3JOH22A[QUOTED] likes this.
  10. Jan 2, 2024 at 2:19 PM
    Technique
    Alex
    Utah
    On their site they say they fit for 3rd gens. I don't recall having to drill anything out of mine. Just popped them in and they were good.
  11. Jan 2, 2024 at 2:21 PM
    Ricardo13x
    Upland, CA.
    I believe @3JOH22A was not aware that there are now a model for 3rd gen. They have not been around for long.
    Taco47 and 3JOH22A like this.
  12. Jan 2, 2024 at 2:37 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
  13. Jan 2, 2024 at 2:38 PM
    Ricardo13x
    Upland, CA.
    And as you know they work wonders. I cringe big time when I see people with aftermarket suspension and OEM bushings.
  14. Jan 2, 2024 at 2:44 PM
    Bob76
    Bob
    They are. There is a reason I stopped taking my truck to the dealership for service. They also add "shop fees" on top of the quoted price that you only find out about when you get the invoice. I noticed them and was unhappy enough with their service that most of the customers that were waiting now know to look for them LOL. Making up BS fees is one thing, adding them on top of your quoted price is a whole new level of stealership. Thanks for the link. For that price I'll probably go OEM.
    3JOH22A[QUOTED] and Ricardo13x like this.
  15. Jan 2, 2024 at 2:46 PM
    Bob76
    Bob
    I don't really go off road. Only reason I/m doing the lift is because I tow and the stock rear leafs are junk, even within the towing, tongue, and bed limits of the truck. To go with heavier springs I pretty much need to lift, unless someone makes stiffer ones I haven't found yet. Even unloaded my leaf springs are flat now.
    Chew and Ricardo13x[QUOTED] like this.
  16. Jan 2, 2024 at 2:51 PM
    Ricardo13x
    Upland, CA.
    I believe they are pretty flat from factory even. But anyway, I recommend stuff that will allow proper use of the other components people buy. But, yeah OEM bushings bind and over a short period of time they’ll show. Cheers my dude.
  17. Jan 2, 2024 at 3:16 PM
    Pili
    Pili New Member
    Not to derail the thread, but if you're happy with current ride height, just order some new leafs from Alcan Spring (https://www.alcanspring.com/). They'll make you whatever ride height/load capacity you want. Love mine.
  18. Jan 2, 2024 at 3:40 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I hope that's actually what's causing the noise. I'd be under the truck with a pry bar checking bushing play myself.
    And keep in mind, if the LCA cam bolts are seized in the sleeves they'll have to be cut out and replaced too
  19. Jan 2, 2024 at 4:00 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Damn, that shows how excessive weight on stock suspension makes things wear out faster.
  20. Jan 2, 2024 at 4:10 PM
    TacoTuesday1
    SD CA
    Dealers replace bushings. TW members replacing bushings. Half of which is pressing a new bushing into a hole. The same as a factory.
    Replacement bushings exist, to be replaced.
    90k is a common suspension wear point.
    I've got used OEM LCA's with aftermarket bushings and LBJ. What you choose is up to you.
    I would not go with a dirt cheap $50 whole arm from China. Made that mistake. The parts sucked.
    I don't know who the supplier is for OEM. OEM arms are good. You can find a deal on them and install them in a parking lot. That is cheaper.
    There are springs made to accomodate bumpers. 90k is a normal bushing wear time.
    Steel bumper does not affect common dealer policy to upsell unnecessary work.
