LCA Ticking Sound???
Discussion in 'Suspension' started by Slimwood Shady, Aug 17, 2012.
  1. Aug 17, 2012 at 2:13 PM
    Slimwood Shady
    Slimwood Shady [OP] I love your mom!
    Linwood
    Hampton, VA
    '17 Tundra; '16 Odyssey; ;14 A4
    I have an 09 DCSB TRD OFF RD w/ 47,200 miles on it. So my left LCA is making a cracking sound when I turn the wheel as well as hit bumps. I have narrowed it down to where it bolts to the alignment tabs. Any idea what could be making it do this...I have included a clip so you can see what I am talking about. The sound starts at about :10 sec
    EDIT: Oh yeah forgot to add...it only does this when the weight is on the wheels. When jacked up, it does nothing....
    THE FIX FOR MY ISSUE WAS I NEEDED TO TORQUE MY CAM BOLTS TO 100 FT/LBS!!!
    http://youtu.be/g5PqhDce_3Q
  2. Aug 17, 2012 at 2:17 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i cant view the vids, but it may be your bushings
  3. Aug 17, 2012 at 2:19 PM
    Slimwood Shady
    Linwood
    Hampton, VA
    Truck only has 47k on it :rolleyes:
  4. Aug 17, 2012 at 2:21 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Seized LCA bolts / bushings / cams would be my guess
    Very common problem
  5. Aug 17, 2012 at 2:22 PM
    97yota4wd
    Eric
    Mesa, AZ
    yeah but look at your signature picture. you wheel, bushings go bad.
    if thats where the noise is coming from id take it apart and see whats going on. it can be any of what oz said. thats what i would go after.
  6. Aug 17, 2012 at 2:26 PM
    Slimwood Shady
    Linwood
    Hampton, VA
  7. Aug 17, 2012 at 2:26 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Could be bushings, could also be related to steering since wheel turning is involved. Seems to only make noise when the wheel is being turned...
  8. Aug 17, 2012 at 2:27 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    def lca bushings
  9. Aug 17, 2012 at 2:28 PM
    Slimwood Shady
    Linwood
    Hampton, VA
    I origanally thought steering, but nothing from there. I had someone turn the wheel as I was under the truck. It was def coming from the LCA due to sound and vibration:confused:
  10. Aug 17, 2012 at 2:29 PM
    Slimwood Shady
    Linwood
    Hampton, VA
    Also should it be moving front and back like that?
  11. Aug 17, 2012 at 2:31 PM
    jandrews
    There's a little flex in bushings. That's why they're there. Yours seems to have a little more than normal.
    Bushing's probably done. That's a good place to start the diagnostics anyway...you can replace them with OEM, but I believe Total Chaos has a urethane kit for their OEM replacement LCAs that would fit and likely last much longer than the OEM rubber...
    Getting them out is the bitchy part. You basically gotta cut 'em outta there.
  12. Aug 17, 2012 at 2:33 PM
    Slimwood Shady
    Linwood
    Hampton, VA
    :mad: or save up for TC LCA
  13. Aug 17, 2012 at 2:33 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    I would say lca bushings but i would have to see it for myself. Bullshit ass rubber bushings
  14. Aug 17, 2012 at 2:36 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    Just like jan said poly bushings are the shit
  15. Aug 17, 2012 at 2:36 PM
    YumaTRD
    YumaTRD 22R...Legends never die
    David
    El Cajon, CA hometown Yuma, AZ
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO's
    So can the tierods may also be causing the clicking?
    I just get one clunk when im backing out of my driveway
  16. Aug 17, 2012 at 2:37 PM
    Slimwood Shady
    Linwood
    Hampton, VA
    Yeah but getting the others out are a B*TCH!!!
  17. Aug 17, 2012 at 2:37 PM
    jandrews
    Your call. Helluva lot cheaper with a few hours extra labor to replace the bushings.
    Got a spare set of LCAs myself so I can at least keep the truck driveable while I do a bushing swap...
    Hacksaw. Punch. Press. With the right tools, it's not too terrible. Doing it without a press would be annoying, but still possible.
  18. Aug 17, 2012 at 2:37 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    who makes polly bushings?
    i dont think anyone does
  19. Aug 17, 2012 at 2:38 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thats how it starts:D:mad:
  20. Aug 17, 2012 at 2:38 PM
    Slimwood Shady
    Linwood
    Hampton, VA
    Joo bring to shoe creek? :anonymous:
