LCA upgrade Recommendations?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Mark86, Oct 11, 2021.
  1. Oct 11, 2021 at 6:50 AM
    Taco Mark86
    Taco Mark86 [OP] Well-Known Member
    Mark
    NC
    09 DCSB with some mods
    Magnaflow, Fox RR/ Camburg UCA up front, Bilsten 5100 and some kind of AAL/ leaf pack in the back?, Light bar w/ Hella, and an air freshener
    Good morning all,
    The ball joints in my LCAs need replacing soon and I’m trying to decide which route to go. I installed Moog oem style a few years ago but am considering some of the more built aftermarkets, I’d like to get something similar to the Dirt King but not looking to spend $1200 or more on these. The moog are about $200, is there anything better in the $4-600 price range?
    truck is an 09 DCSB with camburg UCAs and Icon RR extended travel coilovers up front
  2. Aug 7, 2022 at 3:16 PM
    hamtaco4x4
    hamtaco4x4 Well-Known Member
    Collin
    Silver Spring, Maryland
    2009 V6 SPORT 4X4 4.0L
    I have this exact same question. Did you ever come up with anything?
  3. Aug 7, 2022 at 3:22 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Having been through this myself, I picked up some rebuilt Dirt Kings from a member here (IIRC I paid 750 or 800?)
    Not for the faint of heart, but based on the photos I was sure the arms themselves were in fine shape and I was prepared to buy new uniballs and bushings if the rebuild was questionable.
    Thankfully in my case they were great, but something to factor in if you go with used/rebuilt.
    Key-Rei likes this.
  4. Aug 7, 2022 at 3:43 PM
    Taco Mark86
    Mark
    NC
    I never came up with anything, just went with another set of Moog.
  5. Aug 7, 2022 at 3:51 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I bought the OEM ball joints for a Land Cruiser from a Saudi Toyota dealer on ebay and pressed them into my OE LCAs.
    Was kind of a pain but it's doable.
  6. Aug 7, 2022 at 3:52 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Key-Rei likes this.
  7. Aug 7, 2022 at 11:54 PM
    TacoTuesday1
    SD CA
    I have a set of Moog/Mevotech in storage.
    A set of used that I repainted and will install ASAP, with new bushings and ball joints pressed in.
    Short of that, the upgrade is fabricated/welded steel. I don't know if they come in geometry to mimic stock, or longer travel; likely the latter, or option to pick from either.
    Which would be stronger, serviceable, and possibly better angles + more clearance
    also ~$1-2k+
  8. Aug 7, 2022 at 11:56 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    OEM new is best. Unless you want to go LT.
    wi_taco and airmax233 like this.
