LCA wont swing down...
Discussion in 'Suspension' started by chadderkdawg, Aug 3, 2011.
  1. Aug 3, 2011 at 4:59 PM
    chadderkdawg
    chadderkdawg [OP] Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Trying to remove my front stuts and my lower control arm wont swing down and out of the way... I've loosened the cam bolt... but its still spring loaded and wont move... Help please :goingcrazy:
  2. Aug 3, 2011 at 5:04 PM
    scocar
    scocar hypotenoper
    Disconnect the sway bar?
  3. Aug 3, 2011 at 6:34 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    first thing you have to do is get mad at it...then something will give.
  4. Aug 3, 2011 at 6:42 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    dont you disconnect the spindle from the uca?
    i think thats how we did it on my 2nd gen
  5. Aug 3, 2011 at 7:32 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Spot on, turns out I wasn't mad enough yet, haha, success! Thanks all!
  6. Dec 1, 2015 at 5:06 AM
    awolo
    awolo Active Member
    Aaron
    Medina, OH
    05' DCSB TRD Sport SR5
    1st off, I know this is an old thread. But why start a new one and watse forum space?
    Anyway, I went to install my leveling kit this past weekend. And found that my LCA will not swing down as it should. I loosened up EVERYTHING, tried a pry bar, even gave it some really good wacks with a big hammer. It will move very slightyly down, like 1/4 inch, but spring back up like there is a force on it.
    Any insight? Am I missing something obvious?
    - Removed both knuckle bolts
    - Removed the lower strut bolt
    - Loosened LCA bolt to the frame
  7. Dec 1, 2015 at 7:44 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Sway bar?
  8. Dec 2, 2015 at 11:03 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Ever replaced your LCA bushings?
    Bolts and sleeves might have a lot of corrosion after 10 years in Ohio.
