LCA's. Excessive play. Dealer replaced 2 months ago
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Apr 6, 2015.
  1. Apr 6, 2015 at 9:59 AM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello group,
    Look at this Vid and please give me some input. It's the same on both sides.
    http://s1056.photobucket.com/user/TACRUN1/media/11E10056-8851-4838-9798-1F714F95FB14.mp4.html
    I had to replace my LCA's in January, 2015.
    A former co-worker of mine welded beads behind my alignment tabs WITHOUT removing my original LCA's. I had Toyota of North Miami do the work & he gave me half of the money. Fair enough.
    Ever since then, when I braked I can see my left front tire move. Then I saw that both front tires move. Besides that, if I hit speed bumps at moderate speed they both make a loud metal-on-metal banging sound.
    I took it to the dealership today & they told me to take it back on Thursday when their "lift experienced" tech is there. I explained that Spindles won't affect that and the problem started after the LCA's were installed.
    Can both LCA bushings be defective?
    Thanks group!
  2. Apr 6, 2015 at 11:35 AM
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    It says private video can't watch
  3. Apr 6, 2015 at 11:38 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    could be they just got loose and need to be re torqued
  4. Apr 6, 2015 at 12:32 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Video issue has been fixed. Sorry about that.
    The bolts are very tight. I thought, and hoped, the same thing at first. The dealership even told me that they retorqued it.
  5. Apr 6, 2015 at 12:36 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Maybe the bushings got melted a bit leading to some room for play
  6. Apr 6, 2015 at 12:40 PM
    racer1x
    campbell ca
    05 Taco
    Too many
    probably melted you bushings doing the welding
  7. Apr 6, 2015 at 12:50 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    that bushing is DONEZO replace
  8. Apr 6, 2015 at 12:53 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Yes. That's what happened to my original LCA's. These are the ones that Toyota installed 2 months ago. Actually. My original ones with the burned Bushings weren't as bad as these.
    A mechanic somewhere else told me the same but Toyota did acknowledge that it's excessive. Plus, when I go, I hooe to see another Tacoma there & I'll ask them to show me the play on that truck.
  9. Apr 6, 2015 at 12:55 PM
    nd4spdbh
    SoCal
    that is 100% NOT normal play.
  10. Apr 6, 2015 at 12:56 PM
    OZ-T
    Peter North
    British Columbia
    Huh strange , definitely looks like excessive play
  11. Apr 6, 2015 at 1:06 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    I'm in the automotive field and I am well aware of the occasional defective part but TWO new LCA with bad bushings?!?!?!
    Bad batch?
  12. Apr 6, 2015 at 1:07 PM
    Why J
    Why J I'm the master of my own domain.
    2012 DCSB V6 SR5 Prerunner
    OEM Roof Rack, 3" lift, 1.25" Spidertrax Wheel Spacer, Front skid plate
    I was not looking at it close enough after watching the video again i saw it was moving WAY too much. Which I why I deleted my post.
    But those should be covered by Toyota since a dealer installed them. Have them repaired by the dealer. If the original installing dealer wont play ball go somewhere else.
  13. Apr 6, 2015 at 1:08 PM
    Why J
    You sure you got what you paid for? Just sayin.....
  14. Apr 6, 2015 at 1:21 PM
    nd4spdbh
    SoCal
    yeah, you sure the dealer replaced the LCA? did you get the old part back?
  15. Apr 6, 2015 at 1:26 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If the LCA bolts were tightened with the suspension at full droop rather than loaded, they could well have failed already. The bolts must be left loose until the truck is supported by the suspension, otherwise an excessive amount of torsion will be applied to the rubber at full compression, tearing the rubber or it's bond to the steel sleeve within the bushing.
  16. Apr 6, 2015 at 6:54 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    I may have to go that route.
    Yes. I saw the old parts.
    Really? Damn. Well, if that's the case then it will explain why both have so much play.
  17. Apr 6, 2015 at 6:59 PM
    nd4spdbh
    SoCal
    yup that will do it.
    OP if the dealer installed take it back and have them do it right... noting the suspension should be loaded before tightening.
  18. Apr 8, 2015 at 9:09 AM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
  19. Apr 8, 2015 at 9:11 AM
    OZ-T
    Peter North
    British Columbia
    Glad you got it sorted out
  20. Apr 8, 2015 at 10:50 AM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Thank you.
