LCE and URD Drive train upgrades
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SLVRNBLK, Apr 3, 2017.
  1. Apr 3, 2017 at 6:14 PM
    SLVRNBLK
    SLVRNBLK [OP] Well-Known Member
    Ozzie
    Lithia, FL
    Silver TT
    Very happy so far with these upgrades. Truck feels totally different now.
    Mods:
    LCE Pro Clutch kit
    URD Short throw shifter kit
    scottalot likes this.
  2. Apr 3, 2017 at 8:42 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    What is that shifter bezel? I've never seen cup holder in it
  3. Apr 3, 2017 at 11:47 PM
    Depoxy
    Depoxy Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
    That's the center console from a regular cab with the bench seat.
  4. Apr 4, 2017 at 3:16 AM
    Regcab05
    Regcab05 Well-Known Member
    David
    Atlanta
    05 regular cab 4x4
    Please tell me more about that clutch. That's the one I'm considering.
  5. Apr 4, 2017 at 10:24 PM
    SLVRNBLK
    Ozzie
    Lithia, FL
    Silver TT
    Correct
  6. Apr 4, 2017 at 10:26 PM
    SLVRNBLK
    Ozzie
    Lithia, FL
    Silver TT
    Reviews I read were positive. I like it so far, just in the break-in period. Took just a few hours to install. Cheaper than the URD unit which was the other I was considering
  7. Apr 4, 2017 at 11:02 PM
    2ndgenJack
    2ndgenJack Member
    Was looking into getting that short shifter. How difficult was it to install on the 5 speed?
  8. Apr 6, 2017 at 9:27 AM
    SLVRNBLK
    Ozzie
    Lithia, FL
    Silver TT
    I had a local truck shop do the clutch and shifter install all at once. Easier to do it that way, however the instructions say it's a 15min installation
  9. Apr 6, 2017 at 10:04 AM
    SeanBonham
    SeanBonham Well-Known Member
    Sean
    Derby City
    2012 DCSB SR5 4x4 6mt with some thangs
    Wondering about this clutch as well. You replace or resurface the flywheel?
  10. Apr 6, 2017 at 10:09 AM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    Also curious.
    You had mentioned your original clutch had 150k on it in another thread.
  11. Apr 6, 2017 at 10:11 AM
    SLVRNBLK
    Ozzie
    Lithia, FL
    Silver TT
    Kit does not come with a flywheel, so OEM unit was resurfaced.
  12. Apr 6, 2017 at 10:12 AM
    SLVRNBLK
    Ozzie
    Lithia, FL
    Silver TT
    Resurfaced, shop didn't mention any issues with OEM unit
  13. Apr 6, 2017 at 10:15 AM
    Hondah
    Newnan, Ga
    '13 RC 4x4
    Gotcha, thanks!
    (You're doing everything I'm planning on!)
    SLVRNBLK[QUOTED][OP] likes this.
  14. Apr 6, 2017 at 12:37 PM
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    Yeah, give us another update after break in of the clutch. I've been doing some reading about heavier flywheels. LCE has one for the 2TR $300. I want to do their heavy flywheel too instead of resurfacing the OEM for $50-100.
  15. Apr 6, 2017 at 2:06 PM
    ClayCole
    ClayCole Member
    4cyl 2.7L 2TR-FE
    I have 165K miles on my original clutch, I've been thinking about replacement as well.
    A heavier flywheel would be great, my 2.7L is easy to stall and the flywheel howls a little when slipping the clutch once it gets hot (warped maybe?) and I think replacement with a heavier one might make improve the drive-ability / make it not so easy to stall.
    Curious to hear about the improvements from the new clutch.
  16. Apr 9, 2017 at 9:55 PM
    SLVRNBLK
    Ozzie
    Lithia, FL
    Silver TT
    Im just about at the 500 mile break-in point. So far results have been positive. Feel is pretty much like stock although engagement is slightly different obviously. Can you give me the link to the flywheel on the LCE site? I don't see any 2tr options. Strange how they don't include a flywheel with the clutch kit. I just assumed that the stock unit is fine with resurfacing which is what I did. I'll chime in again once I have a few WOT pulls. Also, just so you know, my truck will be featured in a future episode of "The Smoking Tire" with Matt Farah on YouTube. You can check out my Evo 8 which was just released a few days ago!
    https://youtu.be/RkfglhQxjeA
    BassAckwards, scottalot and Torspd like this.
  17. Apr 10, 2017 at 3:04 AM
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    The re-surfaced OEM flywheel is fine. I'm trying to overcome 1000 lbs. of armor and 35's on 4:88 gears. Just type in 2TR in the search bar on LCE's site it's on page 2. Thanks for the update.
  18. Apr 10, 2017 at 3:06 AM
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    From what I've read the heavier flywheel is good for not stalling off-road, low end torque, and pulling hills on the highway, but bad for acceleration.
  19. Apr 10, 2017 at 6:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Very nice Evo, @SLVRNBLK . He was thoroughly impressed. No need to ask what you have done to it.
    What all do you have done to the truck though?
    SLVRNBLK[OP] and scottalot like this.
  20. Apr 12, 2017 at 6:58 PM
    SLVRNBLK
    Ozzie
    Lithia, FL
    Silver TT
    URD Supercharger Kit with a whole bunch of goodies :thumbsup:
    RyanTacoMC and Torspd[QUOTED] like this.
