LCE + catback is obnoxiously noisy
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4banga, Feb 14, 2019.
  1. Feb 14, 2019 at 1:54 PM
    4banga
    4banga [OP] Semi-evolved monkey
    Colorado
    98 3RZ SC 4WD
    LCE headers & cat-back, Bilstein 5100s & AAL, LR UCA's, CVJ axles
    First of all, I'm so glad I found this website. Y'all are a wealth of wisdom.
    A year ago, I ordered the LCE Headers, Magnaflow cat, and LCE Catback w/ the Magnaflow muffler on my 3RZ. In retrospect, I realize my silliness. The truck is obnoxiously loud, and I don't wanna be the guy waking the neighbors up.
    I think I'll keep the headers, but ditch the 2.5" Magnaflow catback, and replace with a 2.25" pipe going into a good noise-reducing muffler. (Isn't the stock pipe diameter for the 2.7 2.25"?)
    I'm thinking of reducing the pipe diameter after the cat because I rarely rev to high RPMs. This is mostly a farm truck. I know there's a big debate about backpressure and exhaust gas velocity yadda yadda... My question is, will a .25" smaller diameter pipe be more optimal for driving around in the lower RPMs?
    Also, any suggestions for good mufflers that'll keep noise to a minimum?
    I appreciate the input!
  2. Feb 14, 2019 at 2:32 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Do you know which magnaflow muffler you have? There's about 5 different ones.
  3. Feb 14, 2019 at 2:39 PM
    4banga
    Colorado
    98 3RZ SC 4WD
    It came with the LCE Pro Flow kit. It states a straight through design on the site
  4. Feb 14, 2019 at 3:01 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Bosal will get you as close to stock for $120.
    4banga[OP] likes this.
  5. Feb 14, 2019 at 4:11 PM
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    The LCE Proflow catback sounds great on my 3RZ, not loud at all.
  6. Feb 14, 2019 at 4:25 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I think it's close to 2.25. I don't think it's worth changing pipe size, just get a different muffler.
  7. Feb 14, 2019 at 4:31 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Note that the headers make it much louder in the cab. Not necessarily to wake your neighbors, but quite a bit louder driving. The OEM manifold is cast iron for excellent sound deadening. Headers are bent tube and do not deaden the sound. I put headers on my Toyota pickup years ago, I personally like a quieter cab and wouldn’t do it again.
    4banga[OP] and El Duderino like this.
  8. Feb 14, 2019 at 5:25 PM
    FreshOldTaco
    kevin
    2003 Tacoma
    Good to know
  9. Feb 14, 2019 at 5:32 PM
    4banga
    Colorado
    98 3RZ SC 4WD
    Huh. Mine has a really deafening drone to it
  10. Feb 14, 2019 at 5:35 PM
    4banga
    Colorado
    98 3RZ SC 4WD
    Interesting! My cast iron manifold cracked a while ago, but I never thought about the sound deadening properties
    crashnburn80[QUOTED] likes this.
  11. Feb 15, 2019 at 6:09 AM
    1997tacomav6
    Denver
    I just returned the Magnaflow cat I bought at o’Reillys yesterday direct fit,
    Sounds horrible, whole cab resonated evertime I accelerated on my 3.4.
    Also lost a bunch of power above 4000 rpms.
  12. Feb 15, 2019 at 6:58 AM
    FreshOldTaco
    kevin
    2003 Tacoma
    Maybe it’s louder for you with the V6 standard cab, my xtra cab four banger is pretty mellow even at 75mph down the highway.
  13. Feb 15, 2019 at 8:17 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Yeah, it may be beneficial to add some sound deadener to the firewall and footwells.
  14. Feb 15, 2019 at 8:21 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    get like a 24 inch, and chambered
  15. Feb 15, 2019 at 9:16 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I love my magnaflow. I think it's the 14" one? not sure though. I still have a factory cat, but also have the "mini-headers" from the CA emissions 3rz tacos. I think it sounds great from the outside, and is pretty mild on the inside but you can still hear it when you really get on it. It's the perfect balance for me.
    Not sure about the LCE headers though. Since there isnt a heat shield on top of it, im sure the headers themselves produce a decent amount of noise.
