LCE Engineering Short Shifter
Discussion in '1st Gen. Tacomas (1995-2004)' started by TurbulentLamp, Sep 6, 2019.
  1. Sep 6, 2019 at 12:54 PM
    TurbulentLamp
    TurbulentLamp [OP] Well-Known Member
    1999 Toyota Tacoma 2.4L 2WD
    Hello,
    I'm planning on replacing the clutch on my Tacoma this month, and I wanted to install an LCE short shifter while I had the transmission off. However, on the website it is stated to verify if the truck has a 6 bolt pattern that measures 3 1/8'' in width and 5 1/2'' in length. I'm not sure if my truck has these exact measurements and I called LCE engineering and the representative stated that it's better if I check because they didn't make a short shifter for every possible transmission that Toyota put on their Tacomas; they made a short shifter for the most common one. Now, I'm wondering, has anyone here bought and installed a short shifter on their 99 Toyota Tacoma 2.4L 2wd 5spd from LCE Engineering (part # 1097003) without issue? Any help is appreciated. Thank you!
  2. Sep 6, 2019 at 12:58 PM
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    Why do you want that?
  3. Sep 6, 2019 at 1:04 PM
    TurbulentLamp
    I would like to try it out. Also, a shorter throw between shifts would be nice.
  4. Sep 6, 2019 at 1:05 PM
    TurbulentLamp
    Yes. Still stock at the moment. But, I'm fixing and restoring stuff here and there. I have plans for it, but I'm working on it bit by bit.
  5. Sep 6, 2019 at 2:55 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Love my short shifter!! ... I got a marlin crawler one so I can't help with the LCE . But I like the marlin and Hurst (theres a different company making I cant rember the name) style that replaces the housing. Oppose to the spacer. Either way good luck and enjoy.
    TurbulentLamp[OP] likes this.
  6. Sep 6, 2019 at 3:22 PM
    mattyosh
    mattyosh Well-Known Member
    Oahu, HI
    02 TRD Prerunner; 96 SR5
    I have an LCE short shifter installed on my 02 V6 4wd extra cab and love it! Really cleaned up the slop and it goes into gear much easier compared to stock.
    Sorry, I can't verify that the one you're looking at will fit, but do recommend the LCE kit! Also, get the plastic bushing. My factory one was destroyed.
  7. Sep 6, 2019 at 9:03 PM
    TurbulentLamp
    Thank you I'll look up the Marlin Crawler one and see if they're more specific on sizing!
    chrslefty[QUOTED] likes this.
  8. Sep 6, 2019 at 9:04 PM
    TurbulentLamp
    I really just want to go for it and just bite the bullet and hope for the best and hope it fits cause I've heard great things about the kit. Thank you for your response!
    mattyosh[QUOTED] likes this.
