LCE Header and AFE Drop In Filter = Awesome Drivability Upgrade
Discussion in '4 Cylinder' started by matbaugh, Dec 29, 2015.
  1. Dec 29, 2015 at 10:31 AM
    matbaugh
    matbaugh [OP] Active Member
    Matthew
    Hi all-
    So I bought my 2013 4 cylinder in a moment of conservatism--"I can live with the 4" I told myself. The next day I regretted it severely. The dealer wouldn't let me trade up--this led me to spend hours of my days for weeks pouring over these forums and others looking for any possible way of improving what was turning out to be lackluster performance (especially in the hills of Vermont).
    I read about the LCE Long Tube Header and bought one after selling my '04 Matrix--this had a noticeable impact on drivability. But then I also added an AFE Pro-dry filter and I have to say--there is a REAL change in performance and fun factor. I spend most of my time at 60-65 instead of 50-55 and generally do not feel I'm missing out on much HP wise.
    If you're wondering whether or not it's worth it--it is.
    Of course I haven't brought it to a dyno, and probably won't.
    Improvements to the truck include:
    Nokian Rotiiva Tires (very very nice)
    ShearComfort Corder Seat Covers (great match to the interior)
    Roll up Tonneau Cover
    AFE Pro-Dry filter
    20151109_164152_resized.jpg 20151109_164201_resized.jpg 20151109_164105_resized.jpg
    Kees and tacoburrito like this.
  2. Dec 29, 2015 at 10:48 AM
    Wolverinesam
    Wolverinesam Well-Known Member
    New York State
    2013 Tacoma Prerunner 2.7L
    Ooooh, you have the manual!! Jealous. How difficult was it to install the header? Been thinking about one.
    Remember: It's built to haul, not haul ass.
    numbah57 likes this.
  3. Dec 29, 2015 at 10:55 AM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    I love the way access cab trucks look.
    I wish I could swipe your ring gears :)
  4. Dec 29, 2015 at 11:27 AM
    matbaugh
    Matthew
    The Header was actually quite easy to install-though I do recommend putting some PB buster on the exhaust bolts a day in advance.
  5. Dec 29, 2015 at 12:29 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Did you also remove the secondary charcoal air filter? It feel like it had a better response when I did.
  6. Dec 29, 2015 at 12:30 PM
    matbaugh
    Matthew
    I did not--was a bit nervous to do so given what I've read about the MAF sensor.
  7. Dec 29, 2015 at 12:33 PM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    I agree with your take. I too have the LCE header and AFE filter in my 2014 2.7 auto 4x4. Certainly worth the cost!
  8. Dec 29, 2015 at 12:51 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I drill out the rivets on mine so if I didn't like it I could still put it back in but it's been well over a year now
  9. Dec 29, 2015 at 4:31 PM
    tacostache
    tacostache Active Member
    2013 Base Model
    intake and headers
    I also have a 2013 2.7L. Power wise, it's adequate for me. But I've been hearing so many good things about the lce headers I finally pulled the trigger on them the other night. Looking forward to the results. FYI - I have the afe filter and pulled the charcoal filter as well as the intake resonator. I can't say for sure it has changed much from stock performance. Just the intake noise is much louder but in a good way imo. But it does "feel" like it can haul a bit better.
  10. Dec 29, 2015 at 7:22 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I'm tempted to pull the trigger on the intake resonator.
  11. Dec 29, 2015 at 7:33 PM
    tacostache
    2013 Base Model
    intake and headers
    I wouldn't do it banking on performance gains but if you just want a louder intake, I'd go for it. Only took me 30 minutes and it was free. Sounds great at 2500+ rpm.
  12. Dec 29, 2015 at 7:40 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    I like my LCE header. I know you guys are all 2nd gens, but on my 1st gen I give it a thumbs up. I can be in any gear at 1.25k revs on flat ground and not bog.. so it really does drop the torque curve considerably. Keep in mind, if you pull anything out of your air intake you will gain a small amount of high end power at the cost of low end power, so don't do it. The intake will growl a bit louder and deeper, you will lose hauling ability. I may go for an afe pro dry when I finally need a new air filter.. will see.
    One thing I will mention, (probably irrelevant to 2nd gens,) I had to lose the front CAT and do a custom exhaust job to make the long tube header fit.
  13. Dec 29, 2015 at 7:46 PM
    tacostache
    2013 Base Model
    intake and headers
    I could see how removing the intake resonator could have shifted power from low end to high end. But the change feels pretty minimal imo. Maybe once I get my lce header put in, it'll bring the power back down...?
  14. Dec 29, 2015 at 7:50 PM
    WheelInTheSky
    G
    Jackson Hole
    Do you want minimal gains in low end power or minimal gains in high end power?
    Given that you drive a truck, I'll assume you want low end power.
    The LCE header will drop your torque curve (good thing), anything that you do that opens up the intake will allow too much air flow at low revs and be a bad thing.
    There's a lot of info on how intakes and exhaust systems work together both on this site and on the internet. Don't open up your intake or your exhaust on a truck, you may get more noise or a deeper tone but you will lose your low end which honestly is all that your truck really has.
  15. Dec 29, 2015 at 8:10 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Any pics of the LCD header installed? If you have to lose your cat how do you get around the emissions testing?
  16. Dec 29, 2015 at 8:22 PM
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    You don't have to modify the exhaust at all on the 2014 2.7. I don't know about any others.
  17. Dec 29, 2015 at 8:34 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Oops! Misread. Cat is pulled on the 1st gen trucks.
  18. Dec 29, 2015 at 8:53 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Install video.
  19. Dec 29, 2015 at 10:31 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    I watched that a few weeks ago and I thought that was the dumbest before and after. The install portion was nice, but I didnt like how they changed 2 variables. they should have done a header + stock ehxuast vs stock everything
  20. Dec 30, 2015 at 3:00 AM
    Wolverinesam
    New York State
    I changed out to a K&N filter, not the full CAI and I removed the charcoal filter. That's all I'm going to do on the intake side. I did add an AFE catback. My butt dyno swears it opened the engine up a bit but then again butts can lie.
