LCE header support bracket....?
Discussion in '4 Cylinder' started by Pastadog, Aug 30, 2016.
  1. Aug 30, 2016 at 6:33 PM
    Pastadog
    Pastadog [OP] Well-Known Member
    Ronnie
    North Hollywood, CA
    05 SWRC Prerunner
    Touchscreen with hands free blue tooth, charcoal filter removed and resignator delete
    Bought a used header but did not come with a support bracket so it vibrates and breaks exhausts welds making it make a nasty noise at low rpm. Help pleeeease
  2. Aug 30, 2016 at 8:26 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Post a pic.
    The header I have from LCE (Doug Thorley) has never had issues, it's a shorty though. Is the header you have a long tube? I'm not familiar with the year available for your truck.
  3. Aug 30, 2016 at 10:06 PM
    Pastadog
    Ronnie
    North Hollywood, CA
    05 SWRC Prerunner
    I'll had to take one tomorrow
  4. Aug 31, 2016 at 8:37 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Hey Ronnie, :)
    I'd also be interested to see your header as I've run LCE long tube headers on my 2.7 Tacomas (1996 and 2012) with absolutely no issues whatsoever.
    Greg
  5. Sep 6, 2016 at 6:56 AM
    snefo
    snefo Well-Known Member
    Mine buzzes sometimes under load. Needs a bracket.
  6. Oct 24, 2016 at 7:24 PM
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    I had a long tube header on my old 22re. After a few years the collector flange weld broke. Actually the tube just adjacent to the weld broke. It was not thinned out at all though so it was easily welded back on.
    The long tube header I now have on my 2tr has no support bracket. The factory manifold had a support bracket to the block if I recall but the LCE header had no provisions to re use it.
