LCE Headers
Discussion in '4 Cylinder' started by KaosTsoc, Jun 26, 2012.
  1. Oct 31, 2012 at 4:08 PM
    #141
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    This was the hardest park for me, getting those f%$king spring bolts off that connect the header to the exhaust pipe.
  2. Oct 31, 2012 at 4:19 PM
    #142
    Bosmob
    Bosmob Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    The gold pipe is actually not EGR related. Toyota hasn't used EGR systems on their engines for quite some time now. It is actually an Air Injection system that injects air into the exhaust manifold on cold start up to improve emissions.
  3. Nov 1, 2012 at 3:35 AM
    #143
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    As was stated before I got back here, not an issue. Actually it is perfect height to not have to use jack and since my truck is only lifted 1/2" up front it isn't too high to reach either. No battery disconnect, just the snorkel off oem intake from box to plenum. Snake header in from the top and bolt up to head first before tightening up the collector bolts.
    Bummer, hit mine with a bit of WD-40 and was no issue at all.
    OK, fixed.....just gold pipe. But technically, air injected into the exh manifold becomes exhaust gas now doesn't it, it's just not recirculated, lol. EG without the R. :p
  4. Nov 1, 2012 at 5:55 PM
    #144
    Bosmob
    Kevin
    San Diego, CA
    LOL I guess you could see it that way.
    But getting technical... the purpose of EGR is to cool combustion temperatures by introducing inert gases into the combustion chamber. The air being introduced through the gold pipe is not inert and is meant to heat the catalytic converter and fill the converter with oxygen.
    So technically they are different things but they both work towards improving emissions. Also Toyota no longer uses dedicated EGR components but still creates an EGR effect by using VVTi.
  5. Nov 2, 2012 at 4:04 AM
    #145
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I knew you were gonna say that..........that's why I said what I said, to get you to say what you did. It worked.
  6. Nov 2, 2012 at 7:27 AM
    #146
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    That's amazing!!! "I got mind control over Dbo. When he here, I shut up. But when he leave, I be talkin again."
  7. Nov 2, 2012 at 7:32 AM
    #147
    GEORGE STRAIT
    Da Magic City, AL
    hey allmotorrex are you regeared?
  8. Nov 2, 2012 at 9:40 AM
    #148
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    No sir. Not yet. I'm doing 4.88s. I've actually had them for like 8 months and still haven't put them in! Lol but I met a new friend that said he would do front and back for my help and a case of beer :D
  9. Nov 2, 2012 at 10:04 AM
    #149
    stockplus
    stockplus Well-Known Member
    L.J.
    Way way north of Redding
    06 4x4 SR5 Access Cab
    TC, ToyTec, Boztec, All-Pro, ATO
    I placed my order this morning. The guys at LCE were great to talk to. They said the production process had been refined and this header is perhaps superior in some respects to the previous iteration -- though don't quote me on that :D. Still about 3 weeks out for the first batch. I'm glad they're back!
  10. Nov 2, 2012 at 10:10 AM
    #150
    stockplus
    L.J.
  11. Dec 10, 2012 at 5:43 PM
    #151
    TrailerParkJesus
    TrailerParkJesus Member
    Dallas, Texas
    '12 Tundra
    Just installed the headers yesterday. Took me nearly 5 hours from start to finish. Some of the hex nuts were nearly impossible to reach on the old header when taking it off and putting the new one on. Also had to sand the bottom surface of the EGR so that it would fit all the way back onto the header. There was about a 1/2" gap which caused the air injection tube to not sit flush with the header. The header was probably easy to install and I probably made my life harder somehow :notsure:
    There is definitely a noticeable boost in performance especially on the lower RPMs. I don't nearly have to press the gas pedal as hard to get it to go especially from a complete stop. Overall I'd say I'm pretty happy with the purchase though, just the install was not as easy as I thought it would be.
  12. Dec 10, 2012 at 8:30 PM
    #152
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    But its on now so who cares! Lol
  13. Dec 11, 2012 at 5:05 AM
    #153
    TrailerParkJesus
    Dallas, Texas
    '12 Tundra
    My thoughts exactly. Pain in the ass to install but glad it's on and I don't have to worry about it anymore. Just get to enjoy it.
    I know some other posters purchased it around the same time I did. Curious to see their experiences as well!
