LCE heavy flywheel for torque?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TBeers, Dec 7, 2013.
  1. Dec 7, 2013 at 3:36 PM
    TBeers
    TBeers [OP] Well-Known Member
    Montana
    Tacoma DLX 3.4 4x4
  2. Dec 7, 2013 at 3:40 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    In all the engine building books Ive read, they all said a heavier flywheel will increase torque.
    What kind of gains you might see or if it would be worth it on a non-racing vehicle I cant answer.
  3. Dec 7, 2013 at 3:48 PM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    Don't know what stock weight is, but it won't increase torque. If in fact it is heavier than stock, it will have more inertia, revs won't drop or climb as fast when shifting. A lighter flywheel will make the engine more feel more responsive, and revs will fall faster. Looks like this flywheel adds more weight, so mileage may be affected slightly with more rotational mass.
  4. Dec 7, 2013 at 3:50 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    A heavier flywheel? Sounds interesting.
  5. Dec 7, 2013 at 3:55 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
  6. Dec 7, 2013 at 4:26 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I think increasing torque is a misconception. IIRC just makes it easier to tow by maintaining engine momentum. Your RPMs will climb noticeably slower but smoother.
  7. Dec 7, 2013 at 6:49 PM
    TBeers
    Montana
    Tacoma DLX 3.4 4x4
    Thanks for the thread, I didn't find one on here.
    This thread just made me not want one, ha ha ha. Seems like little noticeable difference at low rpm compared to noticeable negative effect on accel and higher end hp. Little gained for the trade off.
    Maybe we would have different results with our 5vzfe's?
  8. Dec 7, 2013 at 6:52 PM
    TBeers
    Montana
    Tacoma DLX 3.4 4x4
    And I was wrong stating that it would increase torque Vigo, your right, just more inertia.
    Funny that LCE advertises it as a "High Torque Flywheel" though.
  9. Dec 7, 2013 at 7:05 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    It's mainly for the holding power for me. I will have full armor, winch, 33" tires, the whole 9 yards. I'm going to try it for that extra low end grunt at take off and climbing.
  10. Dec 7, 2013 at 7:41 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    maybe for a "high torque" application, not necessarily adding more torque
  11. Dec 7, 2013 at 8:29 PM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Inertia, yes - harder to stall. However, if anything you will see a loss in overall engine output. Adding mass to the drivetrain will only drain power, never add. You'll likely notice the lack of responsiveness / ability to hold momentum when grabbing the clutch more than the loss in power, but my CTS-V has a 48lb flywheel and I would switch it for a 17lb Z06 flywheel in a heartbeat. It feels sluggish and it's annoying.
  12. Dec 7, 2013 at 8:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Bingo!
