LCE Throttle Body Spacer
Discussion in 'Performance and Tuning' started by SkyHighTacoma, Sep 13, 2011.
  1. Sep 13, 2011 at 12:17 AM
    SkyHighTacoma
    SkyHighTacoma [OP] Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Okay so this thread isnt about me asking if they work or if I should buy one. I know that everyone says they dont do anything on efi engines. And I think the same. But what about this one? Its from LCE website and they have a dyno chart pic, and since they are such a good company, why would they make it up or lie about the dyno chart that is posted? Im just curious if anyone else has any opinons on this, cause we all say throttle body spacers are just good paper weights..? :confused:
    http://www.lceperformance.com/Throttle-Body-Spacer-Kit-5VZ-p/1061067.htm
  2. Sep 13, 2011 at 12:25 AM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Granted, you'll barely feel 2.2 hp.... but yeah, it is interesting.
    ttt
  3. Sep 13, 2011 at 12:33 AM
    SkyHighTacoma
    Josh
    15 DCSB SR5 MGM
    Yea true. But if your building for power every little bit of hp you can get counts. In the butt dyno you would think you could feel the mid-range 4-6 hp and tq gain, I know I did with the deckplate mod. :D Im just curious if this is true or not..
  4. Sep 13, 2011 at 8:05 PM
    SkyHighTacoma
    Josh
    15 DCSB SR5 MGM
    Bump! I would like to hear opinons! :)
  5. Sep 13, 2011 at 10:09 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    worthless. don't waste your money.
  6. Oct 6, 2011 at 9:09 AM
    Runnerstrom28
    Runnerstrom28 Well-Known Member
    Derek
    Summerville, SC
    05 Black Decepticon DCLB
    Decepticon emblem, 3inch lift, 33inch trail grapplers and XD series Monster rims, Dual Exaust 40 series flowmasters, 18% tint around and 35% tint on front windsheild, 55w 10000K HIDs, blacked out taillights, pioneer deck, kicker 750 mono amp pushin a memphis 12
    Im curious about them too! A buddy on mine has one on his trailblazer nd it makes this sick whistle sound. Im thinking about buying it just for that lol
    Free BUMP
  7. Oct 6, 2011 at 9:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    2.2HP? That's probably within the tolerance range of the dyno.
  8. Oct 6, 2011 at 9:45 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not worth it... 2.2 max HP gain at 4,600 RPM and 4 ft-lb gains at 3,500 RPM is boarderline useless in my opinion (unless you're racing, in which case you shouldn't have bought a pick-up). Show me gains under 3,000 RPM, where most people spend most of their time, and I'm interested.
  9. Oct 6, 2011 at 12:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The only thing it seems to do on the 5vz, is eliminate the OEM gasket, which has a slight "D" shape, as opposed to an "O" shape. Many people with the 5vz have trimmed the existing gasket into an "O" and reported the same gains, but with a cost of $0.00. I suggest, if you are considering this, is to buy the gasket for an supercharged throttle body, or trim the existing gasket. Save cash, and have the same effect.
  10. Oct 6, 2011 at 12:42 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    It also increases the plenum volume very slightly which can possibly add the 2 hp...., I would like to see this test done by a 3rd party dyno, I used to run a shop that did this, we installed, tuned and built electronic devices for performance applications and also did 3rd party testing.
    Its always hard to believe any manufacturers claims especially if they tested it themselves from a biased standpoint.
  11. Oct 6, 2011 at 12:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This ^^^^^
    For that matter, All newer vehicles have tuned intakes. If a simple spacer made that much difference, the manufacture would have lengthened their intakes another 1/2"
  12. Oct 6, 2011 at 1:02 PM
    Speed Freek
    Yeah I know, just trying to throw LCE a bone of sorts, lol.
    As far as plenum tuning, even a very small amount can make a difference (even with the loss of velocity), but it can also cause you to lose power in certain ranges, like you said the OEM spends a lot of money trying to extract as much power as possible within reason..there are quite a few factors at work when it comes to how the air will travel through plenums and ports...I have built several types of manifolds allbeit for forced induction vehicles so it does not really apply to NA motors the same exact way since under boost it is being force fed..
    If the TB spacer worked as well as they say Toyota would have made the plenum 3/4 ish inches deeper like you said, I am sure they tuned it to be as good as it can get for whats on the table...
    IMO TB spacer = less gas money, lol. And that Fking stupid whistling sound...gawd!
  13. Oct 6, 2011 at 1:10 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    You guys are missing the most important thing of all here...
    Does it make the bad-ass whistling noise when you step on the gas??? :D
  14. Oct 7, 2011 at 8:56 AM
    Runnerstrom28
    Derek
    Summerville, SC
    x2 lol :cool:
  15. Oct 8, 2011 at 7:54 AM
    Speed Freek
    Install a muffler from a Toyota Previa S/C, it will whistle dixie all day long.
    When I used to test drive them when I worked for TOyota it drove me nuts and EVERY one of them did it, next time you see one (if you ever do) listen for it, lol.
  16. Oct 13, 2011 at 9:36 AM
    jtlachac08
    jtlachac08 Well-Known Member
    Jeremy
    Phoenix, Az
    I can account for both 1st and 2nd gen V6 TB spacers. Both from Airraid. I put one on my 08 4.0 and my roommate put one on his 01 3.4. Here's the butt dyno results:
    08 V6 Results-
    Not really any performance gain, infact I couldn't feel anything, but did gain 2+mpg more, and it makes the sweet whistle noise under 2000rpm. 2nd gens dont have the "D" gasket so it really didn't open anything up. Just "twirling" the air and Airraid describes it.
    01 3.4 Results-
    Installed and right away snappier throttler, no more D gasket. No whistle on his 1st gen.... On the freeway the truck screams now. Definitely opened it up and got a 1+mpg gain.
    Not too bad of an upgrade for under $100 IMO
  17. Oct 13, 2011 at 10:32 AM
    jtlachac08
    Jeremy
    Phoenix, Az
    Ya he considered that or just getting the SC gasket. I guess he wanted more of the "I have a throttle body spacer" attitude.
  18. Oct 18, 2011 at 11:35 AM
    Runnerstrom28
    Derek
    Summerville, SC
    Thanks for the info bro! Im thinkin about throwing a tb spacer on shortly :cool:
  19. Oct 18, 2011 at 11:39 AM
    Runnerstrom28
    Derek
    Summerville, SC
    well if i get a lil improvement on mpg then im happy:D
    honestly i just really want that whistle sound :cool:
  20. Oct 18, 2011 at 1:45 PM
    jtlachac08
    Jeremy
    Phoenix, Az
    OH it definitely whistles! I WOULDN'T do that muffler turbo junk, I dont see any mpg gain in that....just saying.
