LCE underdrive crank pulley
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4banger4x4, May 8, 2014.
  1. May 8, 2014 at 5:56 PM
    4banger4x4
    4banger4x4 [OP] Probably should'nt have done that.
    Eric
    Whorelando, Fl
  2. May 9, 2014 at 2:32 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Wow interesting. So all you need is a new belt size and bolt on? I imagine this would pair well with replacing the stock fan with a electric fan. Maybe even removing the balance shaft?
  3. May 9, 2014 at 3:06 PM
    4banger4x4
    Eric
    Whorelando, Fl
    you might not even need new belts if you have enough adjustment in your pulleys.
  4. May 10, 2014 at 1:35 AM
    n0ms
    Angel
    San Diego
    Okay I will buy it eventually and report back.
    1997tacomav6 likes this.
  5. May 11, 2014 at 11:17 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    All of the above, and it would be a definite seat of the pants improvement.
    You are under driving those accy's, so expect the unexpected due to it being a different truck. Alum pulley's can wear really fast,,depending on the load placed. This is a crank pulley, so it's taking the full brunt.
    Although the inst don't mention it, I would definitely keep a eye on the torque setting of that centerbolt. It's just high performance regular maintenance for alum aftermarket parts.
    Surely LCE has done there homework, and will gladly help you step by step with little tips.
  6. May 11, 2014 at 11:26 AM
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    Hmmm I'd be real curious as to a before and after dyno run to see how much of a gain there might be. Sounds good though as long as they don't decrease the water pump and other accessories.
    Of course you will feel it in the seat of your pants lol you just spent money on a performance upgrade so psychologically you want to feel it.
  7. May 11, 2014 at 12:43 PM
    n0ms
    Angel
    San Diego
    Thanks for the info, maybe I'll pick this up at the end of the month.
  8. May 11, 2014 at 2:14 PM
    4banger4x4
    Eric
    Whorelando, Fl
    Thanks for the info. Maybe when I have some extra cash ill do this, or ill just add it on to my order when I order my rebuild kit :) im truck desperately needs more power to the wheels
  9. Aug 11, 2020 at 5:18 PM
    Saiko
    Saiko Well-Known Member
    Saiko
    Chicago
    00 2RZ w59 2wd
    i need to bring this back from the dead, and then i could answer all ur questions.
    iv bought this pulley and also going the electric fan route, IF someone could help me by telling me the demn belt size, my adjuster works fine all the way both ways but the current belt is too long...how do i figure this out belt gurus?
    DANKE!
  10. Aug 11, 2020 at 5:49 PM
    paetersen
    paetersen Well-Known Member
    You folks do realize the only real benefit and reason for the existence of underdrive pulleys is for race engines running way above stock rev limits so the accessories don't turn too fast at say, 10,000 rpms?
  11. Aug 11, 2020 at 6:47 PM
    mtb_taco
    mtb_taco Well-Known Member
    2001 Tacoma
    Hope this helps.
    - OE Alternator/Water Pump is 86.5cm / 34", replaced it with 85cm / 33.5" belt (PN 5PK0850 / 4050335)
    - OE AC is 87cm / 34.25", replaced it with 86.5cm / 34" belt (PN 5PK0865 / 4050340)
    - OE PS is 108cm / 42.5", replaced it with 106.5cm / 42" belt (PN 4PK1065 / 4040420)
  12. Jan 25, 2021 at 5:14 AM
    95tarbilly
    95tarbilly Member
    Jon
    96 Tacoma 2.7
    None yet.
    Good point. But losing a few pounds of rotational mass has to help
  13. Jan 25, 2021 at 6:34 AM
    CR, WA
    stock
    That's what helps you get to those 10K rpms quicker as well, with the 4 kits of spray + water inject 890in Reher motor. Member to shift right!!, don't do a 1-2-1.
  14. Jan 25, 2021 at 8:58 AM
    95tarbilly
    95tarbilly Member
    Jon
    96 Tacoma 2.7
    None yet.
    Right. I do some LS turbo drag racing with some friends. Gotta get spooled up quick. As far as my little 2.7 I'm just trying to get it to not shit on itself pulling out from a red light.
    Underdrive crank pulley, stage one cams, light porting, aluminum radiator, electric fans, header and exhaust.........I hope to see a little improvement.
    mtb_taco likes this.
